5088 front end capacity?
Amo in Nebraska
01-30-2008 14:45:44
Was wondering how much weight a person could put on the front end of a tractor. A budy has an attachment for a dozer blade on his 4440. When he is not using the blade he has a bale fork on there to haul an extra bale out to feed. I have a double bale carrier for a three point. If I got a dozer and made an attachment for 3pt would this be too much wt up front? 2 bales @ 1625 and the carrier 750-1000#? That should be much more than a front end loader would it?
Any way your thoughts would be great!
Thanks
Gary
Lee in Iowa
01-30-2008 21:11:49
 Re: 5088 front end capacity? in reply to Amo in Nebraska, 01-30-2008 14:45:44
One thing you might want to look at is how close to the tractor you will be carrying the weight. If its a lot closer to the tractor than with a loader it should help. Also if your 5088 is MFWD or a late model 2 wheel drive with the square tube front axle it should be pretty stout. Lee
Mulcher
01-30-2008 19:21:31
Last year we picked up large square corn stalk bales (about 1350# apiece) two at a time with a loader on our 1086. Bouncing across the rows and going with to put them on a trailer. Probably not good for it but didn't break anything. I'm guessing 5088 has a heavier front axle.
Brian
