F12 Flywheel housing
kam
01-30-2008 18:44:13
Hi,
Does the Flywheel housing have a gasket between it and the block?
The engine gasket kit (from fordson house) did not come with one.
The only concern is sealing the rear camshaft journal, the rest is dry of course.
I have already had to get gaskets from Rice that the kit was missing...wish I knew about Rice before.
Thanks
steelfronts
01-31-2008 14:21:58
 Re: F12 Flywheel housing in reply to kam, 01-30-2008 18:44:13
The gasket kits are not complete any more as far as I can tell. There needs to be a gasket between the block and bell housing to keep camshaft oil in.
Dave Allgire
01-31-2008 07:36:42
There is a gasket between the flywheel housing and the block. It fits between the bolted surfaces (top half). It provides a seal for the open end of the camshaft. The part number as listed in the parts book is 24419-D. Again, Rice Equip. has it. I agree you could probably use some RTV around the cam opening, but if you have a gasket, why not use it? Just my thoughts.
James Williams
01-31-2008 05:36:10
kam,theres no gasket,I just removed mine last week to install a starter mounted bell housing
jimmy
ET
01-31-2008 04:41:48
I made a gasket for my F12 to go in there. The area behind the camshaft will have oil under presure in it. Plastic gasket maker would work well there and be easy to do.
Fawteen
01-31-2008 01:19:28
No, there is no gasket.
farmall/allischalmersman
01-30-2008 19:17:30
yeah rice equipment is excellent on new parts sry i dont remember if there was a gasket between the bellhousing and the engine block
i dont think there was a gasket but im not sure
all of our gaskets for our f12's and f14's sets never came with that gasket
