Rim repair
Mr. Mayor
02-01-2008 05:10:21
I have some brand new rear tires for my H and I bought them on the rims. One of the rims has some small dings. I plan on having them unmounted so I can blast and repair the rims. I want to heat the curled spots on the outside edge and tap the metal back into place. Has anyone done this? Successfully?
ephhs
02-01-2008 18:45:09
 Re: Rim repair in reply to Mr. Mayor, 02-01-2008 05:10:21
My father and I have a neighbor that visits our shop. If he has a bolt or nut he cannot get to turn, he wants one of us to use the "BIG WRENCH". Donot heat your wheel.Use a hammer and a piece of railroad steel.This works for us. ephhs
wijim
02-01-2008 12:47:22
blue flame persuader
Mr. mayor
02-01-2008 09:47:24
Thanks for the advice fellas
old
02-01-2008 08:59:16
DON'T heat them or you can make thing worse because if you heat them they will start looking like a rattle snakes belly. Just take a hammer and a iron block and hammer them back to where they should be. Remember they are tractor rims not car rims and it they are not 100% straight they will still be just fine
gene bender
02-01-2008 05:45:12
The posts are cottect as i have straightened several with crestent wrench and pipe wrench. Sometimes using a piece of hard wood so as not to mark the rim then sanding the marks they will look like new again. Using a primer after sandblasting and then the I-H SILVER. Some then clearcoat realy look nice all depends on your effect when done.
mkirsch
02-01-2008 05:32:06
 Re: Rim repair in reply to Kevin Meier, 02-01-2008 05:10:21
Definitely just bang them back into place. Heating will change the properties of the metal, making it softer and easier to bend the next time IIRC.
RustyFarmall
02-01-2008 05:23:03
You can do it without the heat. In fact, it would be better if you didn't use any heat.
w.g.
02-01-2008 05:13:22
yes it can be done , i have found the best way to do this is using a cresent wrench
Allan In NE
02-01-2008 05:19:34
 Re: Rim repair in reply to w.g., 02-01-2008 05:13:22
For sure,
Either a big cresent wrench or a pipe wrench with a cheater bar. You can pull those "dings" right out in no time.
I'm not a real big fan of the red and green wrench.
Allan
CWL
02-01-2008 06:30:46
 Re: Rim repair in reply to Allan In NE, 02-01-2008 05:19:34
"Red and green wrench" Hmmm that's a new one to me. We always call it the "hot wrench". Ya learn something new every day on this site!
Red Mist
02-01-2008 11:17:33
 Re: Rim repair in reply to CWL, 02-01-2008 06:30:46
I noticed that also. Good name. We always called it the "blue tipped wrench", and sometimes the "gas ax" for a cutting torch. This is a wonderful forum, as you say. mike
