460 PTO adjustment/fix
old
02-01-2008 09:04:24
Talked to a friend this morning and he has a 460 that the PTO will not stop on it. My manual doesn't cover the 460 so my question is it adjusted like the 450s is or is it different?? If its different can some one scan and send me the page from there manual or explain it to me so I can then explain it to him?? Thanks
Owen Aaland
02-01-2008 11:02:29
 Re: 460 PTO adjustment/fix in reply to old, 02-01-2008 09:04:24
If it has the band style like the 450 the adjustment is the same. If it is the later style with the over center clutch, then the adjustment depends if it is the later housing with the adjustment plug hole or you may have to disassemble it to do the internal adjustment.
