Hydraulic ports on SMTA?
MCR
02-01-2008 10:31:27
Hello: I wanna put port blocks on my SMTA instead of hoses w/ports. I just think it'll be easier to connect hoses as well as being neater in appaerance. My question is all the port blocks I've seen have 4 inlets, and not 2? I only have two hoses from the hydraulic pump, so why do blocks have 4 connections to tractor? and can I find any with two connections (pressure and return) connected to tractor? Like on the 400's or 450's only without metal tubing. Thanks for any thoughts on this. Mark R.
mkirsch
02-01-2008 11:21:22
 Re: Hydraulic ports on SMTA? in reply to CenTexFarmall, 02-01-2008 10:31:27
Most tractors these days have two hydraulic remotes. There is little to no market for a two-port block.
To be "correct" not to mention safe, your Super MTA should have two hoses running to quick-disconnect couplers in a yoke. All these parts are available at TSC.
