1942 A PTO QUESTIONS
ray pell
02-01-2008 10:53:16
I removed the belt pully on the top pto to inspect seals a found that the gruves in the shaft extend into the seal/bearing somwhat is this corect or what am i looking at exactly?
gene bender
02-02-2008 03:56:11
 Re: 1942 A PTO QUESTIONS in reply to ray pell, 02-01-2008 10:53:16
When you removed the belt pulley there should have been a bushing about 1in long over the belt pulley shaft where the seal is cause if its gone there is no way to stop the lube from leaking out. It slides over the splined shaft and acts as a spacer.
RAY PELL
02-02-2008 06:55:36
 Re: 1942 A PTO QUESTIONS in reply to gene bender, 02-02-2008 03:56:11
Thanks Gene i'ts missing.Any ideas on whear to find one.
Thanks, Ray
Kristof
02-01-2008 10:59:42
Doesn't the seal seal on your belt pulley?
On my C the seal seals on the cilyndrical part of the pulley. The pulley is kept onto the axle with a bolt wich also seals it. The grooves do reach the bearing.
Hope I could be of any assistance.
Kind Regards,
Kristof
