Keith-Or, Hugh MacKay Others
Chris from Wa
02-01-2008 23:20:04
I haven't been around much recently and thought that I should check in. Keith and Shawn, how is the C restoration going? Is it done? If so, how did it turn out? Hugh, I see that you're still around. Beat up and monks recently? How is it going up in the big white north? Migraine, I hope you're surviving. We are seeing our share of snow and ice down on the Olympic Peninsula. Although my truck route takes me 300-400 miles per day, it keeps me west of the passes and out of the avalanches. My Super-C is still torn down, awaiting the engine rebuild before I do the restoration. The good news is that my lady gave me a used industrial compressor for Christmas. Now I can finally get a decent sandblaster and get things rolling.
Keith-OR
02-02-2008 11:21:29
 Re: Keith-Or, Hugh MacKay Others in reply to Chris from Wa, 02-01-2008 23:20:04
Chris, was just thinking about you the other day, wondering what happened to ya. I happened up on pic. of your SC while back with WFE.
We are close to the end of our project. I found a WFE in Moses Lake, did a few repairs to it and have it put on Shawn's SC. Almost everything is painted and put back together. Our hold up is trying to find another new Power Mark rear tire by Kelly tires, they have quit making this particular tread design. So I guess we'll just have to find one that is close and call it a day.
Still need to install decals we got from Rustyfarmall.
Keith & Shawn(Special Olympic Champion)
Couple examples of paint job as you will notice, I decided to paint the alternator red also to blend in a little better.
third party image
third party image
Keith-OR
02-02-2008 17:53:08
 Thanks Chris , Andy (Cheap paint) in reply to Keith-OR, 02-02-2008 11:21:29
Paint is the cheap CNH paint with a special harder I found... Which give ordinary paint the wet look. Ya don't need to spend high dollar on paint to get great finish!! If ya want name of hardner email me
Keith & Shawn
Chris from Wa
02-02-2008 13:33:37
 Re: Keith-Or, Hugh MacKay Others in reply to Keith-OR, 02-02-2008 11:21:29
Nice paint! She should be a real beauty when you get her done.
Andy Motteberg
02-02-2008 13:21:57
Wow! Great paint job!!
migraine
02-02-2008 08:14:24
Oh we are enduring the winter. Lost a few days of work this week with the snow but gives more time to work on tractor stuff. Been working on finishing a 650 Diesel which now runs good and almost everything working, pretty neat old tractor actually that will be repainted later, working on a 450 Farmall gas putting in a new clutch and TA and then fix leaks and ready for the paint room, getting started on 350 Diesel Farmall binging back to original condition and then hopefully to the paint room, just got a 136 fast hitch disk and took it to the paint room yesterday, and picked up a 106 Cub Cadet with front blade that we will work on today for awhile. Hope to move some snow with it yet this winter. And a few other projects that come up so if you are bored and need a fix on I.H. iron give me a call and well have lunch and get in a few hours. Migraine
Chris from Wa
02-02-2008 09:03:28
 Re: Keith-Or, Hugh MacKay Others in reply to migraine, 02-02-2008 08:14:24
Migraine, it sounds like you're keeping busy. You must have quite the collection by now. Thanks for the invite.
Hugh MacKay
02-02-2008 07:32:17
Chris: I must be missing something, you keep refering to this subject of beating up on monks. Send me an e mail, something else unrelated I want to ask you.
gene bender
02-02-2008 04:03:16
Even though you say a your new air compresser is commercial doesent mean it is capable for sand blasting. Its not pressure its CFM for sand blasting and you need aaround60 or more unless you want to take a week to do what could be done in a day. You can build a blast tank out of a 100lb LP tank as its not hard to do but the first thing you need to know is what psi and cfm your compresser will furnish as that will determine which nozzle and sq ft per minute you can do.
Chris from Wa
02-02-2008 09:07:11
 Re: Keith-Or, Hugh MacKay Others in reply to gene bender, 02-02-2008 04:03:16
Yep Gene you're right. My compressor only puts out 20 cfm. But that is enough air with an 1/8 inch nozzle to do what I need.
dave guest
02-02-2008 16:57:19
 Re: Keith-Or, Hugh MacKay Others in reply to Chris from Wa, 02-02-2008 09:07:11
Love that red paint!!! Excellent.
