Order Farmall Cub Parts Online
How to remove Farmall Cub exhaust valve?
Eli Roy
02-02-2008 07:11:55
I have a 1957 Farmall Cub that I am trying to get running but I have one sticky exhaust valve. I have purchased a new valve and spring but cannot figure out how to get the old valve out. What is the proper procedure for changing the valve- or even the improper procedure as long as it works! Thank you!
xcubber
02-02-2008 17:14:48
 Re: How to remove Farmall Cub exhaust valve? in reply to Eli Roy, 02-02-2008 07:11:55
Went through this a couple years back. If'n you're nimble, you may be able to use two wide bladed screwdrivers to get one out. A small magnet is very helpful for the keepers. I pulled all of mine out and broke down and got a Craftsman valve compresser,~$20 and worked fine. One that works on B&S engines will work also. Whatever ya do, DON"T drop a keeper down into the oil pan, don't ask how I know;-)
billde
02-02-2008 09:20:27
You will need a valve spring compressor for a flathead, you may be able to rent one from a parts store. Compress the spring, remove the keeper, release the compresser, spay the valve with a good penetrating oil, tap the valve out.
Bob
02-02-2008 13:45:01
 Re: How to remove Farmall Cub exhaust valve? in reply to billde, 02-02-2008 09:20:27
It would be INTERESTING to watch him "tap" a valve out of a "flathead" engine!
billde
02-03-2008 17:41:52
 Re: How to remove Farmall Cub exhaust valve? in reply to Bob, 02-02-2008 13:45:01
Stop by some time I'll educate you.
ihc49er#2
02-02-2008 07:35:16
first would be an engine miss then diagnose from there.
P and R Pete
02-02-2008 07:23:29
Sorry Eli, I don't have your answer, but a related question for those who do-
How do you tell that a valve is sticking? Do you have to watch the rockers? Can you hear it through the cover? See it out the exhaust? Feel it in the driving?
Bob
02-02-2008 07:20:45
There's all sorts of shop manuals "on-line" at Rudi's Cubs.
http://www.cleancomputes.com/Cub/
