Wiring problem
Tom Windsor
02-02-2008 10:06:26
I am being a little dense here and cannot get the issue resolved satisfactorily. I have a G Allis Chalmers that I have rebuilt. For the life of me I cannot figure out how to properly wire the Generator, the cut out, and the 3 position switch in the proper fashion. Does anyone either know the wiring diagram for this tractor is or have a site I can go to to get the wiring diagram. This is of course a positive ground tractor.
Second question: When properly wired and running, if you disconnect the battery, will the engine continue running?? (that is, is it supposed to continue to supply power to the coil?)
TW
James Williams
02-02-2008 14:34:22
 Re: Wiring problem in reply to Tom Windsor, 02-02-2008 10:06:26
Tom,It should run,but this is not reconmended,if one cable is pulled a ground,or positive runs wild and could fry somthing.I seen this happen on a boat and all of the wiring hardness was fried instanctly
jimmy
SuperA-Tx
02-02-2008 11:52:45
Check this out Tom.
Link
Tom Windsor
02-02-2008 13:28:58
 Re: Wiring problem in reply to SuperA-Tx, 02-02-2008 11:52:45
Thank you Thank you. I looked everywhere and could not find this.
tw
Andy Motteberg
02-02-2008 11:24:45
 Wrong forum?? in reply to Tom Windsor, 02-02-2008 10:06:26
Is this supposed to be on the AC forum??
Dave Sherburne NY
02-03-2008 19:45:10
 Re: Wrong forum?? in reply to Andy Motteberg, 02-02-2008 11:24:45
Glad Tom didn't use all caps or spell something
wrong
James Williams
02-02-2008 14:36:25
This is not a AC or Farmall forum,its a people forum.Tom keep on asking
jimmy
Andy Motteberg
02-02-2008 19:13:51
 Re: Wrong forum?? in reply to James Williams, 02-02-2008 14:36:25
This forum is called Farmall/IHC, but if he can't get n answer on the AC board, he can post here or on Tractor Talk.
CNKS
02-02-2008 13:26:46
Tom was a regular poster on this forum for a long time -- he is just asking the people that know.
Tom Windsor
02-02-2008 13:23:51
No, ;but this is the only forum where anyone knows anything :-)
Andy Motteberg
02-02-2008 13:35:55
 Re: Wrong forum?? in reply to Tom Windsor, 02-02-2008 13:23:51
Yep! That's true!!!
