How to remove belt pulley on NT F-20
scott rukke
02-02-2008 18:49:27
How do you remove the belt pulley on a narrow tread F-20? It is no where near coming off the spline before hitting the bull gear. Please don't tell me I have to remove the bull gear.
Scott Rukke
02-03-2008 20:19:30
 Re: How to remove belt pulley on NT F-20 in reply to scott rukke, 02-02-2008 18:49:27
Took the 4 bolts off and it came out. It was still tight and took a bit of wiggling and fenagling. They sure don't give you much room. Thanks fr the help
F-Dean
02-03-2008 10:13:05
When you remove the 4 bolts and loosen the flange, the pulley and the exterior drive should slide off. The two parts of the dtive mechanism fit together in a slot mechanism. You shouldn't have to drain the transmission if you don't mind dripping a little oil-maybe a cup or two. The bearing in the side of the transmission should keep most of the oil inside.
SproutW
02-02-2008 19:05:33
You have to remove the whole assy. from the base of the pulley that mounts to the transmission. Remove the four nuts and slide the pulley and shaft as a whole. Then you can separate the pulley from the shaft.
Scott Rukke
02-03-2008 07:31:35
 Re: How to remove belt pulley on NT F-20 in reply to SproutW, 02-02-2008 19:05:33
Do I have to drain the tranny oil?
SproutW
02-03-2008 07:45:18
 Re: How to remove belt pulley on NT F-20 in reply to Scott Rukke, 02-03-2008 07:31:35
You have to drain it to that level at the least. Or loosen the nuts a tad and break the seal loose and let the oil drain while the pulley is still attached. Your choice. I would just drain the whole tranny and replace the leaky seals and gaskets while you have the oil out. Or maybe you've already done that.
Andy Motteberg
02-02-2008 19:10:31
I thought of that too, that must be the right way to do it!
Andy Motteberg
02-02-2008 18:55:58
Does it come off if you remove the rear wheel? Or is the transmission in front of the pulley? I can't remember.
scott rukke
02-02-2008 18:58:38
 Re: How to remove belt pulley on NT F-20 in reply to Andy Motteberg, 02-02-2008 18:55:58
The rear wheels are off. It hits the bull gear almost immediately after you try to slide it off the spline.
Nebraska Cowman
02-03-2008 04:24:58
 Re: How to remove belt pulley on NT F-20 in reply to scott rukke, 02-02-2008 18:58:38
The correct pulley for the NT has more offset. You may have the wrong one.
Farmallgray
02-03-2008 08:54:51
 Re: How to remove belt pulley on NT F-20 in reply to Nebraska Cowman, 02-03-2008 04:24:58
The correct pulley on an NT only gives you enough room between it and the bullgear to slip a belt in there.
SproutW
02-03-2008 08:02:34
Howard I was thinking the same thing as you and then I tried putting the regular (non-offset) pulley on the NT and it would not fit.
Scott Rukke
02-03-2008 07:30:31
The pulley has a lot of offset but still won't come off by itself. The measurements for the pulley are 15-1/4" by 6-1/2" and the spokes are offset nearly all the way to the outer edge. According to the measurements the pulley would be part #31619DX although I haven't found the casting number yet.
