Compression check
junky old Farma
02-03-2008 05:20:13
What should I be getting for compression on a healthy C engine?
kossuth
02-03-2008 08:12:43
 Re: Compression check in reply to wegman in mn, 02-03-2008 05:20:13
Then you're good to go as far as compression goes.
Janicholson
02-03-2008 06:21:39
 Re: Compression check in reply to junky old Farmalls, 02-03-2008 05:20:13
Assuming that the throttle was open, and the starter was spinning the engine with all spark plugs out for the tests, A dual fuel C will be between 90 and 110 psi
a gasoline only will be more than 120 to 145.
Putting a tablespoon or so of oil should raise it less than 5#. if more it may need rings. 10% variation is more than expected, and low cylinders may have compression leaks. Gasket/valve/piston rings/piston. Good luck, keep us informed, JimN
junky old Farmalls
02-03-2008 07:44:27
 Re: Compression check in reply to Janicholson, 02-03-2008 06:21:39
thanks, I'm 110 to 120 psi on all cylinders. Oil didn't seem to make any difference in compression readings.
Janicholson
02-03-2008 20:00:36
 Re: Compression check in reply to junky old Farmalls, 02-03-2008 07:44:27
It is in the ball park.
Higher compression is not needed. though it would make more power on todays gasoline, it is powerful enough to spin the wheels anyway. These are traction limited tractors. Good luck, and keep us informed on what you do with it. JimN
