966 oil leak
JMar
02-03-2008 07:06:09
I recently purchased a very good running 966. It does have one leak that I would info on. It is leaking engine oil through the inspection plate on the righ hand side of the tractor behing the engine. I assume this is the rear main leaking?? Will that saturate the clutch?? How hard to fix??Any info regarding this will be appreciated. Thanks, JMar
Lynn Davis
02-03-2008 11:52:56
 Re: 966 oil leak in reply to JMar, 02-03-2008 07:06:09
Time consuming,has to be taken into at flywheel housing, to replace the seal and wear ring you will need the right driver, wear ring installer.
JMar
02-03-2008 13:26:29
 Re: 966 oil leak in reply to Lynn Davis, 02-03-2008 11:52:56
Thanks Lynn for your response. Since this involves breaking the tractor, will I hurt the clutch or shorten its life if I don't fix right away?
Thanks again.
