Super M brake rebuild
Jaden
02-03-2008 13:33:05
I need to rework the disc brakes on my '53 Super M. Any particular words of wisdom?
Thanks!
John
r4etired
02-03-2008 18:07:13
 Re: Super M brake rebuild in reply to Jaden, 02-03-2008 13:33:05
If your disc's are bad I recommend you take them to a good brake shop and have them relinned, All disc's you buy today are aftermarket including those from CIH,The materials in them are so hard they will glaze up and be worthless,
GordoSD
02-04-2008 08:46:41
 Re: Super M brake rebuild in reply to r4etired, 02-03-2008 18:07:13
I used a real rough round wood rasp on the new discs. Made a world of difference. Of course then I drove about two rounds cutting hay with the parking brake on a little. The smell of something hot led me to a smoking housing. Oh well, rough em up again and start over.
Gordo
David Goode
02-03-2008 14:40:26
Make sure you replace the little rubber "boot" that the adjustment bolt comes out off, that is if you don't have it to begin with. It's a pretty easy job, make sure everything in nice and clean. -David Goode Coggon, IA
ScottyHOMEy
02-03-2008 13:46:36
Pretty straightforward job.
But don't be bashful about new balls and springs. They'll make a world of difference. And don't forget to polish up the rmps for the balls.
Nebraska Kirk
02-03-2008 13:45:56
OEM tractor parts offers a rebuild service. Drums & expanders turned, new disc pads, actuator balls and boots.
