1962 farmall 504 spindle problems
jeff s
02-03-2008 14:53:31
i recently bought a 1962 504g with a wide front end.
broke a spindle and find out now they are rare as hens teeth to find. As i understand it ih used outside vendors to make these (shwartz,...shultz? maybe. at any rate i've got a local guy turning and welding one to specs.but its taken forever, has anyone else had this problem?- any sources for the right spindle?- should i change out the front end?
Kevin Meier
02-03-2008 19:04:38
 Re: 1962 farmall 504 spindle problems in reply to jeff s, 02-03-2008 14:53:31
I believe that I can get new spindles for schwartz wide fronts
Vapet
02-03-2008 16:50:36
Are you sure it isn't aftermarket to start with. Many tricycle fronts have been changed out over the years. Used to be about every farm type catalog you opened would have wide fronts listed.
Allan In NE
02-03-2008 15:17:25
Part # 371429R91 at any CaseIH dealer in the world.
What's supposed to be so rare about 'em?
Allan
jeffs
02-03-2008 15:35:08
 Re: 1962 farmall 504 spindle problems in reply to Allan In NE, 02-03-2008 15:17:25
i've been told that IH had some wide front ends built by at least two different companies as well as producing their own, (please feel free to set the record straight if you know differently)- so it's not a IH part.- in fact both spindles on this tractor look to have been repaired already.- sounds strange i know.
Allan In NE
02-04-2008 03:20:32
 Re: 1962 farmall 504 spindle problems in reply to jeffs, 02-03-2008 15:35:08
Your tractor might indeed have an aftermarket front end. No, IH didn't put it on there, someone else did somewhere along the line.
Now, it's just a matter of finding out what make you have so that you can get the needed parts.
Allan
jeffs
02-04-2008 05:23:13
 Re: 1962 farmall 504 spindle problems in reply to Allan In NE, 02-04-2008 03:20:32
thanks guys, any tell tale signs to identify who manufactured the front end?- where would numbers be?- nothing sticks out
