1953 international 340 utility tractor
tooltime
02-04-2008 12:49:55
third party image
here is my winter project, this international was all orange as the state of minnesota owned this tractor, I completely overhauled the engine, clutch, and cleaned/ removed all the old paint off, i have more pics of before shots, and will post picture of compled tractor.
Mark W.
02-05-2008 11:16:14
 Re: 1953 international 340 utility tractor in reply to tooltime, 02-04-2008 12:49:55
Looks great, my 340 is about 6 months behind. What brand and paint number did you use? Any hardener??
tooltime
02-05-2008 15:56:34
 Re: 1953 international 340 utility tractor in reply to Mark W., 02-05-2008 11:16:14
i used martin senouir paint from napa with reducer and hardner also added uv protector. this paint is available from napa auto stores, its not cheap but it will hold up for years to come, also i used a epoy based primer with hardner, have to use extreme caution while using this product, no open flames , heater or spark sources. as far as paint codes, This brand paint has a data base world wide and can match your color you need by tractor model and year.
J.J. from Afton
02-05-2008 05:18:11
Yah that is a nice looking job, soon it'll look good as new. Our old 340 will eventully get put back to her old work clothes. Used to be a state of Minn. tractor than was a county tractor down in the Southeast corner of the state when she was finally painted red+white, although you can see tons of the yellow and orange under it now.
PaulW_NJ
02-05-2008 04:32:11
third party image
Looks really good . . . you're doing a great job! What paint are you using? My '58 340U's been "almost back together" for a couple years now. Would like to see more before/after photos of yours . . . maybe they will motivate me to get going. Did you have any hydraulics issues on yours? I had to rebuild mine. I'm adding an IH 1701 loader, and hope that 9 gpm camshaft driven pump will be enough.
tooltime
02-05-2008 06:22:36
 Re: 1953 international 340 utility tractor in reply to PaulW_NJ, 02-05-2008 04:32:11
on my 340 the only hydraulic problem is that the rear tubes that run to the back block the one was leaking , so i brazed it , and will see if it holds. i have power steering, and should have gone through it with new seals and such, it seem to work ok , i hope i wont regret that, now that everything is painted. i have transmission driven pump . i think its 11 gal pm. i love tractors!
Maark
02-04-2008 16:43:43
So you didn't repaint it orange. It had that set of cloths all it's life. Now it's lost all it's history, and value...
ScottyHOMEy
02-04-2008 18:52:13
 Re: 1953 international 340 utility tractor in reply to Maark, 02-04-2008 16:43:43
Yabbut, those 50's era Minn DOT decals are the very devil to come by. She'd be nekkid without 'em.
Harold H
02-04-2008 15:32:52
Nice 340, but, it cannot be a 1953. The 340 was not introduced until 1959.
Harold H
tooltime
02-04-2008 17:01:23
 Re: 1953 international 340 utility tractor in reply to Harold H, 02-04-2008 15:32:52
your right , i think i was told it was a 1958, i will look at the serial # 3327 p-x is this right ??
Harold H
02-05-2008 04:58:31
 Re: 1953 international 340 utility tractor in reply to tooltime, 02-04-2008 17:01:23
Serial number 3357 is a 1959 model.
Harold H
Janicholson
02-04-2008 13:27:47
Very Nice. JimN
STRAHL
02-04-2008 12:54:20
Nice 340, my dads 340 U is still in the shop. It's a diesel in need of injectors. What size tires are on the front?
tooltime
02-04-2008 13:19:34
 Re: 1958 international 340 utility tractor in reply to STRAHL, 02-04-2008 12:54:20
the fronts are 11L-15 8 ply firestone, the front axel is a non adjustable heavey duty axel.
rears: 14.9-28 firestone
