PTO Shield for H and M
Slydog
02-04-2008 19:11:35
Are the PTO shields on an H and M the same? If they are different was is the difference? I need one for an H so any help would be appreciated.
RustyFarmall
02-05-2008 06:55:06
 Re: PTO Shield for H and M in reply to Slydog, 02-04-2008 19:11:35
You can probably find one right here on YT. Otherwise any Tisco or A&I dealer can get you one. The aftermarket reproductions are very good quality and authentic.
mkirsch
02-05-2008 05:27:56
 Re: PTO Shield for H and M in reply to Mike CA, 02-04-2008 19:11:35
No, they are not the same. Strangely enough, the H's PTO shield is a few inches LONGER!
For the PTO to work without chattering too much on corners, the tip of the PTO shaft and the hole in the drawbar need to be a certain distance apart. Also, the hole in the drawbar needs to be a certain distance from the axle so the implement doesn't hit the tractor's tires. An H's rear end housing is smaller, so to make that all happen, the PTO shaft sticks out of the back of the tractor more than on an M.
If you use an M's PTO shield, it won't cover the whole shaft on an H.
Glenn F.
02-05-2008 10:07:59
 Re: PTO Shield for H and M in reply to mkirsch, 02-05-2008 05:27:56
So is the shaft itself longer or does the housing stick out farther?
Glenn
slydog
02-05-2008 08:27:04
So does anybody have the measurements of the shields so when I search for one I will be sure to get the correct one for an H? What is the length of the H shield vs. the M shield?
TimWafer
02-05-2008 05:23:03
heres one I found on Ebay
TimWafer
02-05-2008 05:22:55
Nebraska Cowman
02-05-2008 05:21:57
The difference is the length of the mounting tabs. If you get one for an M you will have to lenghthen the tabs to fit your H.
Randy in NE
02-05-2008 04:37:44
A salvage yard should have one to fit your H. OEM has them for about $64.00.
john *.?-!.* cub owner
02-04-2008 20:01:25
and there are different shields depending on which pto it is equipped with.
Janicholson
02-04-2008 19:14:07
They are not the same. A good fabricator cold make a go of it, but an original is better. JimN
