Farmall 460 overheating Fast!!!!
Redsm
02-05-2008 17:27:08
460 farmall, diesel 282ci, proper size electric fan, 2 year old radiator, radiator never seen a feild, new 160-170 thermostat, full of coolant, has electric "auto meter" water temp gauge "works" Tractor can be driven about 15 minutes and gets up two about 210-220 fast seems like!!! and pores coolant out the "overflow" tube Bigtime!!!!!
Tractor done this once befor but took thermostat out because i thought that was the problem, left it out and ran it for the time being till i got a new thermostat for it"done fine" slow about warming up, and just recently about 2 weeks ago put it in and is now back two the same thing. all stared one time when i changed coolant in tractor."last fall"
Any help would be appriciated,
Thanks
Tan67
02-06-2008 13:48:46
 Re: Farmall 460 overheating Fast!!!! in reply to Redsm, 02-05-2008 17:27:08
If head was cracked i fiqured it would do it all the time.
j.c.n.
02-06-2008 06:29:22
fyi. make sure you have a ihc thermostat. they have double use. when cold they heat up the block. when the motor is hot, they close off the block and push through the rad to cool. if this helps. i have seen this happen.
El Toro
02-06-2008 06:19:39
Look for bubbles in your radiator. Allan may have found the problem. Hal
dhermesc
02-06-2008 05:33:33
I don't know so I'll ask - what is normal operating temp for a 282 diesel? 210-220 doesn't sound hot enough to be causing the problem you are seeing.
Allan In NE
02-06-2008 06:19:08
 Re: Farmall 460 overheating Fast!!!! in reply to dhermesc, 02-06-2008 05:33:33
180° and it just about takes a court order to warm 'em up in the wintertime.
Allan
Allan In NE
02-06-2008 05:22:41
Cracked head.
Allan
Brownie450
02-06-2008 04:00:18
Don't assume that the new thermostat is good. My brother got a new stat from NAPA & it was bad--his pickup behaved just like you are saying. He also has a 4010 gas which he changed out the coolant one time & had all kinds of trouble--belching coolant out the filler-lots of stuff. Finally changed the coolant back out & used distilled water with the anti-freeze---no more problems. Your stat is in the correct way, isn't it? I guess I'd go with the pump impeller being loose on the shaft if the stat checks out.
K.B.-826
02-05-2008 19:33:48
You've got a 282 and an electric fan. That tells me you've made some modifications. What else have you done? Turned it up some? These engines like to blow head gaskets when pushed too hard. Check the water pump like Hal said, make sure thermostat is installed correctly.
El Toro
02-05-2008 19:02:39
If the belt is tight your pump may be the problem.
Touch the bottom hose and see if it's cooler when the temp is up. It may be the impeller. When the engine is cold look in radiator when the engine is at an idle and see if the coolant is moving. Hal
Tractorfan1
02-05-2008 18:04:55
 Re: Farmall 460 overheating Fast!!!! in reply to glennster, 02-05-2008 17:27:08
Maybe the engine timing is off some?
a_lead
02-05-2008 18:02:44
Red:
Not sure what the temp should be for the coolant, but possibly you have the radiator over-filled. The radiator needs some of the head room for expansion when hot.
On my 340 I can just barely touch coolant on the end of my index finger when cold.
Edward
