706 weight
daveminn
02-05-2008 17:44:56
Could someone help me out on the weight of a 706 diesel and the length?Am shipping one in to Minnesota and our trucking firm needs to know these dimensions.Thanks,for any help yopu can give.Dave Ahlgren
K.B.-826
02-05-2008 19:25:21
 Re: 706 weight in reply to daveminn, 02-05-2008 17:44:56
The spec Kevin gave you is dry shipping weight with base equipment. 706 fully equipped with 18.4x34 rear tires full of fluid can easily go over 10,000. Could also have a rack of 12 100 lb. suitcase weights and a stack of rear wheel weights. As you can see, there"s no way to tell. Better just be safe and guess high, say 13,000 lbs. and 15 feet long, or get someone to weigh and measure it.
Kevin Meier
02-05-2008 17:52:34
Weight: 7642 lbs [3466 kg] Wheelbase: 97.5 inches [247 cm] got this from the tractor data website hope it helps
