Rocker Are Ratio
The_H_That_Ate_My_Brain
02-05-2008 19:03:05
Does ANYBODY know the true rocker arm ratio for a farmall H ? Please no Bull Sh*ters !!! Murphy"s shows they have 1.7 and 1.9 ratio"s....is the 1.7 stock or close to stock ratio?
I really need someone with a straight answer or someone to steer me in a clear direction where I can find out ! So all you H freaks....ball"s in your court !
Thanks for your time in advance.
akb
02-07-2008 01:21:32
 Re: Rocker Are Ratio in reply to The_H_That_Ate_My_Brain, 02-05-2008 19:03:05
Its listed as 1.55 on the cam card I got back from berry cam
Janicholson
02-06-2008 16:07:56
Sense no one answered, I will tell you how to measure it. Put a wooden dowel in the rocker shaft hole that fits tight (sand it to fit) find the center of the dowel, and mark it. Use a caliper to measure from the center of the pushrod socket to the mark in the dowel. Measure from the center of the valve contact pad to the center of the dowel. Express these as a ratio, like 1.124": 1.66" this is then placed in a calculator as 1.66 divided by 1.124 = 1.477 this is the ratio's larger number. Thus the ratio is 1:1.477
This is close enough to call it 1:1.5. I hope this is sufficient. JimN
02-09-2008 07:32:05
 Re: Rocker Arm Ratio in reply to Janicholson, 02-06-2008 16:07:56
Thank you very much JimN and akb, You both have been very helpful. Thanks Again.
