Can anyone identify this F-20 manifold
scott rukke
02-05-2008 19:39:58
third party image
It is stamped 5367 D. The problem is the offset flanges that go against the head, my standard manifold hold downs won't fit. I can make something but thought maybe there is something already out there. There isn't enough room between outer pipes to get the hold in and the 2 outer flanges are definitely different heights.
Scott Rukke
02-06-2008 08:12:20
 Re: Can anyone identify this F-20 manifold in reply to scott rukke, 02-05-2008 19:39:58
I see that Fordson lists a manifold for an F-30 but it has a casting of #5167-D. Mine is 5367-D.
Scott Rukke
02-06-2008 12:23:59
 Re: Can anyone identify this F-20 manifold in reply to Scott Rukke, 02-06-2008 08:12:20
third party image
Mike French sent me this picture of his F-20 manifold which is identical to mine including the gov tube bracket. Thanks everyone for your help.
Nebraska Kirk
02-06-2008 08:02:08
Are you sure that is an F20 manifold? It looks like an F30 manifold to me. The F20 manifolds I have seen are a one piece casting and have an extended part on the lower left side that supports the governer to carb linkage. third party image
third party image
Scott Rukke
02-06-2008 08:06:29
 Re: Can anyone identify this F-20 manifold in reply to Nebraska Kirk, 02-06-2008 08:02:08
Well it was bought as an F-20 so I can't say for sure. Are they interchangeable? This one bolts right up. As for the governor tube support I have a separate piece that bolts to the tube and the left hand nut on the manifold. Everything bolts up including the carb and the exhaust tube which has a cast flange. But this is the reason I am asking and gave the cast number.
Nebraska Kirk
02-06-2008 08:18:48
 Re: Can anyone identify this F-20 manifold in reply to Scott Rukke, 02-06-2008 08:06:29
I don't know if they are interchangeable or not. There are two reasons why I think your's is an F30 mainfold, the lack of the gov. tube support and because your's is a 2-piece manifold. Since you say everything fits, then maybe they are interchangeable.
the Unforgiven
02-06-2008 08:44:01
 Re: Can anyone identify this F-20 manifold in reply to Nebraska Kirk, 02-06-2008 08:18:48
It's not for an F30, the 30 head is at least two inches longer. My gas 30 manifold is #5167 D. Hey Scott, do you still need shutter linkage?
Scott Rukke
02-06-2008 11:30:00
 Re: Can anyone identify this F-20 manifold in reply to the Unforgiven, 02-06-2008 08:44:01
Yes I still need the shutter linkage.
Scott Rukke
02-06-2008 08:24:05
As for the governor tube support I have one but it's a separate piece that bolts to the nut on the left of the manifold. It does look similar to the F-30 manifold with the exception of the height of the flanges. The one you pictures looks like a single nut and washer would suffice to hold down the flanges whereas mine is higher on one flange which would require a hold down such as the 2 that were on the original manifold. The 2 that won't fit on this one. Heck if I know.
scott rukke
02-05-2008 19:41:46
third party image
You can see the close proximity of the 2 flanges where the step keeper should fit.
MIKE FRENCH
02-05-2008 23:21:23
 Re: Can anyone identify this F-20 manifold in reply to scott rukke, 02-05-2008 19:41:46
Yes there is a bracket that goes there. It hold down the intake and the exhaust with a stud and nut. Can get photo tommorow of one. Staufer salvage should have some, call them at 785-966-2739 Tell them I gave you the number. Hope this helps, mike email is open if need more help.
scott rukke
02-06-2008 07:01:13
 Re: Can anyone identify this F-20 manifold in reply to MIKE FRENCH, 02-05-2008 23:21:23
I guess I'm wondering why the hold downs are different than the factory hold downs which I have. My original kerosene manifold with the heat lever was broke so I replaced it with this one assuming the hold downs would work but they won't fit.
