Wiring on Super M
Ryan J
02-06-2008 19:06:35
I converted my Super M over to 12 volt. Now it will fire but it won't run. I used Robert Melville's wiring digram.
Jossette
02-07-2008 16:04:45
 Re: Wiring on Super M in reply to Ryan J, 02-06-2008 19:06:35
third party image
did you switch polarity at the ammeter???
Bob M
02-07-2008 05:06:13
Ryan - Presuming your wiring is correct and the plugs are not fouled there's two things I would check:
1 - Ignition timing. If the distributor's very much out of time the engine can pop and fire but won't run. Static timing for the Super M should be 0 deg (= TDC).
2 - Coil. If you used a so-called "12 volt" (internally ballasted) coil AND a series ballast resistor, the combination will cause current thru the coil to be too low to give good fire at the plugs. Simply eliminate the series resistor and you'll get a nice, hot spark.
Ryan J
02-07-2008 11:58:50
 Re: Wiring on Super M in reply to Bob M, 02-07-2008 05:06:13
It ran fine before I rewired it, and I used the orginal coil.
