806 Range Transmission Cover Reinstall
mhalter
02-07-2008 07:16:42
Whats the secret to getting the Range cover back on a Farmall 806? Is the reverse shaft supposed to be installed in the frame and the cover set on or should the shaft be in the cover and inserted into the frame? When I finally got it all lined up (Putting the cover on with reverse shaft in the cover), it stopped about 1/4" from going all the way down. I thought it was the reverse shaft fitting tight in the shift fork and I gave it a few light taps with a hammer and long story short I popped the cast cam. So now I'm waiting on a new cam to come. Its one of those things that just really ticks you off and I really don't see how I even broke it with just a few light taps of a hammer. Anyway, I don't want to do this again, so any tips and tricks would be appreciated.
mhalter
02-07-2008 16:42:01
 Re: 806 Range Transmission Cover Reinstall in reply to mhalter, 02-07-2008 07:16:42
Okay, so the shaft goes into the fork in the transmission and then install the cover? Should everything be in neutral or should I have it in L or H? Thanks!
mhalter
02-08-2008 18:33:36
 Re: 806 Range Transmission Cover Reinstall in reply to mhalter, 02-07-2008 16:42:01
Got the new cam today. Installed the cover with the reverse shift fork already in the transmission and everything fit like a glove. Thanks for the advice.
Joe Schmitt
02-07-2008 12:42:44
On an 806 you should have the shaft in the fork ,then align the spline on the top. Without having the side cover off I don`t think you could align the shaft and woodruff key. The fork wants to lean out without support. I`ve replaced many rev shirt forks that broke from aggressive shifting. Hope this helps.
