Update on water in oil on M
1 Dollar
02-07-2008 12:29:59
Due to homework and school, I haven't done as much as I would have liked so far, but I can't change that.
Got the head off and the head gasket didn't look too bad at all. No blown out places and it showed no signs of leakage around it. I filled the block back up with antifreeze, drained the oil and now I have had the crankcase drain plug open for 2 days and I have gotten A FEW antifreeze drops along with remenants of oil. (I haven't had time to pull the pan yet, that is next though)
Am I in the market for a new block yet? Would stop leak possibly fill this suspected block crack? What should I look for with the pan off? Any suggestions on what I do next?
Thanks again
CHIEFEAVES
02-08-2008 14:22:37
 Re: Update on water in oil on M in reply to 1 Dollar, 02-07-2008 12:29:59
HAD WATER IN THE OIL PAN ON 1939 M AND IT WAS A RUSTED OUT FREEZE PLUG ON THE FRONT OF THE BLOCK BEHIND THE FRONT PLATE. THERE ARE ALSO TWO FREEZE PLUGS ON THE BACK OF THE BLOCK.
1 Dollar
02-08-2008 11:41:45
I'm going out now to pull the oil pan, so you'll hear back soon.
Thanks
El Toro
02-07-2008 15:31:50
You may have a hole in one of your sleeves. You should've pulled the pan and looked for any antifreeze drops on the sleeves. Losing the rust inhibitor in the antifreeze may have cause that if
you find a sleeve wet. I would have that head magn-fluxed for a crack if there's no leakage from the sleeves. I had this problem on a GM car. Hal
IH2444
02-07-2008 12:39:08
Might be a cylinder sleeve seal ?
RustyFarmall
02-07-2008 13:20:44
 Re: Update on water in oil on M in reply to IH2444, 02-07-2008 12:39:08
An M has dry sleeves. There are no seals. I'd put my money on a cracked cylinder wall, but I hope not. You need to drop the pan, and then shine a bright light up into the cavity and see where the drips are coming from. A cracked cylinder wall is not the end of the world. It can be fixed.
JT
02-07-2008 17:03:36
 Re: Update on water in oil on M in reply to RustyFarmall, 02-07-2008 13:20:44
Is there any possibilty that a cracked head could cause this problem, also? I have been told a cracked head is common on an H, is it also common on an M and could cause this? I am asking for my own education on this.
Jim
Janicholson
02-07-2008 17:15:31
 Re: Update on water in oil on M in reply to JT, 02-07-2008 17:03:36
Yes, but in this case the head is off the block is filled with no head on it checking for block leaks. Because there is no added pressure, the leak might be slower in showing itself. But it will usually show up. It eliminates the head from being considered. JimN
JT
02-07-2008 20:25:29
 Re: Update on water in oil on M in reply to Janicholson, 02-07-2008 17:15:31
OK, I thought he had antifreeze in oil before he pulled head and now just a few drops like it could be still be draining rest of it out. Thanks Jim
