Hydraulic Remote Valves
Charles Todd
02-07-2008 16:04:28
I have a Farmall 504 and I currently have two remotes. I have a loader (in transit) that I am installing. I plan, for the time being to use these remotes for the loader functions. I have been told that the spools are modular and I can stack more than two. I just purchased genuine IH Shop and Parts Manuals last night from SSB and Ebay. I hope to find some part numbers there. Anyone know if these valve spools fit multiple models through the years or were they model specific? What about the hollow bolts and such, do they have longer ones for 3 and 4 valve spools? Any help is appriciated.
PaulW_NJ
02-07-2008 18:00:58
 Re: Hydraulic Remote Valves in reply to Charles Todd, 02-07-2008 16:04:28
Oops . . Just checked my parts CD, and the valves are totally different. Sorry.
But they may manifold in the same way.
PaulW_NJ
02-07-2008 17:25:45
third party image
I don't know about the 504, but my 340U has a manifold in which valves are stacked horizontally. I had to rebuild and put new Orings in all of mine. Each side is a machined surface, with O-rings grooves that seal one to another. . . the fluid passes from one valve to another thru three ports on their sides, which includes high pressure and low pressure. The long bolts are solid. My valves, from left to right,are the safety/pressure relief valve, Teledepth (Fasthitch) valve, and the two remotes that are used for my 1701 loader. The valves themselves have been used on many other models I have seen, including my 240U, which I also rebuilt. I see no reason why you could not add a 5th valve, providing longer bolts and that you have enough space to mount it. Another option is to remove the two plugs from the bottom of a valve and run to remote connectors. In that case both remote pairs will be controlled by that valve, so you would have to add additional valving in the lines to determine which remote you wish to be active.
Charles Todd
02-08-2008 02:54:25
 Re: Hydraulic Remote Valves in reply to PaulW_NJ, 02-07-2008 17:25:45
Thank you PaulW_NJ, the 340U and 504RC are in the same era, but that valve banks appears different. May be because it is not mounted. I will post a picture of mine. My work ports are on the bottom of the valves via a banjo type fitting.
