Hugh MacKay 140 Numbers
Patrick Ouellet
02-07-2008 16:30:15
Did not find casting numbers you refered to. Have numbers from engine block.
123CT2U133863*
If these numbers don't help, where might I find the casting numbers you mentioned?
Hugh MacKay
02-07-2008 19:37:42
 Re: Hugh MacKay 140 Numbers in reply to Patrick Ouellet, 02-07-2008 16:30:15
Patrick: I'm assuming this number, 123CT2U133863 is stamped just below number 1 spark plug, right or wrong? If it is stamped, 133863 is the engine serial number, and if that be so, you have a 1974 - 140.
Casting codes are cast in place using raised digits. If as I assumed above the tractor is a 1974, the letter in you casting date code should be S or T. The other mater to look for here is IH may have stopped using letters in the date codes and it could in fact say 74. I've seen this some in castings as new as the 70s.
Patrick Ouellet
02-08-2008 04:42:40
 Re: Hugh MacKay 140 Numbers in reply to Hugh MacKay, 02-07-2008 19:37:42
Hugh, thanks for your prompt response and your information. Those numbers were in fact below the #1 spark plug.
Patrick Ouellet
02-08-2008 04:42:21
