timing engine
tooltime
02-07-2008 18:43:39
on the ih 340 tractor it has a gas c-135 engine . did i time this ok, i first got # 1 cylinder up on compression stroke, then found where rotor was pointing and hooked that plug wire to number 1. i started the tractor and seem to run a bit rough, i then turned the distributor until the motor sounded good. i did not have timing light, so have no clue how close iam, i can say the engine sounds nice at all levels of rpm's thanks for any input. Jim Gordon
tooltime
02-08-2008 10:47:29
 Re: timing engine in reply to tooltime, 02-07-2008 18:43:39
thanks everyone so much, sure is a great tractor site, you are all very helpful,Jim
Brownie450
02-08-2008 03:50:48
Engines will overheat if timed too slow also. I'd buy a good timing light. You will use it more than you think.
ShaggyM
02-07-2008 22:24:10
I listen to them and if they sound good idling I turn them (retard)back until they sound like they have a slight load. Or until you hear a change in the exhaust noise.
Shaggy
Wesley Stephens
02-07-2008 20:21:16
I've timed a lot of truck motors this way and had good luck. I don't know if his opinion was correct or not, but an old mechanic once told me that after a timing chain got a little worn, a light didn't mean much anyway. If it runs good and the valves don't rattle under load, you should be good to go.
ScottyHOMEy
02-07-2008 19:24:02
A lot of folks didi it that way for a lot of years and made out just fine.
You might find you need to tweak her some once you put a load on her. Just keep an eye on your temps for a short bit to make sure you don't have it too far advanced. If so, retard her a bit and check her out again.
tooltime
02-07-2008 19:28:15
 Re: timing engine in reply to ScottyHOMEy, 02-07-2008 19:24:02
thanks for the info, will the temp rise if its to advanced, and what causes that ? you can tell im new to mechanical fixing , but iam willing to get my hands dirty and learn , thanks again, Jim Gordon
ScottyHOMEy
02-08-2008 07:16:14
 Re: timing engine in reply to tooltime, 02-07-2008 19:28:15
The advice from the other guys is also very good. The link below appears to be from a guy who works on Volkswagen's but his explanation of timing and its effects is generic. Thought yuo might find it helpful.
