Pictures of inside of engine (antifreeze issue)
1 Dollar
02-08-2008 13:18:24
Here's a picture of the #2 cylinder between the sleeve and engine.
third party image
Here is the middle main bearing with the antifreeze drops on it, right below #2. #3 is in the background.
third party image
What do you guys think?
Thanks again
DCW
02-08-2008 17:41:42
 Re: Pictures of inside of engine (antifreeze issue) in reply to 1 Dollar, 02-08-2008 13:18:24
What model engine we looking at?Is it an H engine,or an M?
1 Dollar
02-08-2008 20:51:37
 Re: Pictures of inside of engine (antifreeze issue) in reply to DCW, 02-08-2008 17:41:42
1952 M
Andy Motteberg
02-08-2008 17:13:37
That does not look good! Are you fixing that engine or not?
r4etired
02-08-2008 15:09:44
Remember when these tractors were in their prime anti freeze for most farmers was cost prohibitive. Most were drained every nite and refilled the next day,this caused a lot of scale buildup in the block and heads, Also caused hot spots,especially on the sleeves,Eventually it caused the sleeves to crack, some didn't show up for years,others show up when the new antifreezes are used as they contain corrosion and rust inhibitors.Freeze cracks I have found will generally lock up the piston. My 2cents worth.
Janicholson
02-08-2008 13:35:59
Old is right. It will be necessary to pull the sleeve to see what is going on. It probably could be repaired with a repair (thick) sleeve then rebored to fit the thin standard sleeve. JimN (I assume because I forgot, that this is a dry sleeve engine. If it is an A B C type wet sleeve, it is the sleeve seal O ring, JimN
old
02-08-2008 13:21:38
Bad sleeve seals and or a cracked block either one or both can/will cause that problem
