farmall super A serial #'s
stan w mckaskle
02-08-2008 16:27:42
I just purchased a Farmall super A and want to know what year it was made. The id plate has the numbers 29263? and 540 stamped underneath it. any info would be appreciated. ill post pics later this evening.
Hugh MacKay
02-09-2008 02:35:22
 Re: farmall super A serial #'s in reply to stan w mckaskle, 02-08-2008 16:27:42
Stan: I agree with Scotty, the number 540, should actually read 1540, high idle for a Super A.
ScottyHOMEy
02-08-2008 18:27:36
You might try cleaning it upa little bit and see if that isn't 1540. The second number on the Ser.# plates was usually the no-load high idle speed. On one of my tractors it was pretty obviously stamped by hand -- 15 with one die, and 40 in a slightly different size numbering that was a little crooked from the 15. I don't know as I've ever seen two digit-stamps like that anywhere else.
Red Mist
02-08-2008 18:30:58
 Re: farmall super A serial #'s in reply to ScottyHOMEy, 02-08-2008 18:27:36
Hey, I bet you're right on that, Scotty. Good thing you mentioned that. mike
Red Mist
02-08-2008 17:12:24
In addition to what Andy provided, 292637 is the serial number and 540 is the tractor's power take off operating rpm. Serial number charts are on the left side of this page under Research & Info. Click on Farmall then Super A. mike
Andy Motteberg
02-08-2008 17:16:17
 Re: farmall super A serial #'s in reply to Red Mist, 02-08-2008 17:12:24
I knew what the 540 was for, but I forgot what it was when I replied.
Andy.
Andy Motteberg
02-08-2008 16:58:19
Your Super A is a 1950. I'm looking forward to seeing those pictures!
Andy.
