SC and dual wheels
georgeky
02-09-2008 20:57:04
third party image
I missed the dual wheel post about SC's the other day, but here is mine stuck in the creek. The duals will not hurt your tractor, and in most case(Hugh) the SC has more than enough power to turn them for some jobs. I have used this set up for many years to mow low laying river and creek bottom land to keep from tracking it up so bad. It works great. That is an 8 foot 4 inch Ford mower it pulls every year. The belts on the mower will slip before tractor runs out of power.
Idaho Ron
02-10-2008 15:01:20
 Re: SC and dual wheels in reply to georgeky, 02-09-2008 20:57:04
Hey George. What is that brown streak going down the seat and to the deck? Oh, never mind.
Man that looks scary on a couple of different levels. I would not want to trade you places with my SC. I would be a little shaken up after that. I have some stuck farmall pic's I am going to have to find. Nothing like that though. Ron
georgeky
02-10-2008 21:33:03
 Re: SC and dual wheels in reply to Idaho Ron, 02-10-2008 15:01:20
Hey Ron, wasn't a bit scary. That is just an old washed out road. I doubt you could turn a SC over with duals on if you tried. Best thing is they are light, and the M or 666 will pull them right out. I hung the 666 and 15 footer up in a wet spot, and had to have a dozer to get it out. It sank to the PTO shaft. If I had been on the SC and duals it would have went right across it.
karl f
02-10-2008 12:23:11
 Re: SC and dual wheels in reply to GA Dave, 02-09-2008 20:57:04
ScottyHOMEy said: (quoted from post at 12:25:47 02/10/08)
This little part of the thread sounds to me a lot a couple of old guys around my neighborhood who will tell anybody that will listen that the other one is a no-good, big-mouth, know-nothin' fool, but they still show up at the store every mornin', sit down at the same table with their coffees, and call each other names. If one of 'em doesn't show up, the other will break down, buy a paper and but a paper check the obituaries.
then it's likely he'll utter either "that old ___ ain't deat yet?!" or "the nerve of him dyin without lettin me tellin him what i REALLY think"
karl f
georgeky
02-10-2008 21:36:42
 Re: SC and dual wheels in reply to karl f, 02-10-2008 12:23:11
Karl, you are right. It doesn't bother me any to annoy Hugh a bit now and then. We been going back and forth over a SC for a while.
I still maintain that if one tractor was all I could have to survive with it would be the SC. I am not saying the SA/100/130/140 are not great little tractors(They are) I just prefer the SC.
Red Mist
02-10-2008 05:32:41
Hey, George! Welcome back. Been missing you. I wondered if you went into hibernation or went to Florida. Anyway, welcome back to the forum.
mike durhan
georgeky
02-10-2008 09:46:13
 Re: SC and dual wheels in reply to Red Mist, 02-10-2008 05:32:41
Hey Mike, I just been busy with some things here. Mostly mud, and these old cows are calving. I have been reading the forums a bit, but just haven't been posting to much.
glennster
02-10-2008 04:25:24
where ya been hiding george???? havent seen you lurking here in a while. looks like your sc got caught in the "one more round" dilema. you know, when ya look at somethin and say..... i think i can make one more round and i'll be done. then when you try it..... .dang shouldnt a done that..... ..gets me every time, whether bush hogging when a rains coming, disking near a wet spot, or thinking one more round oughta fit in the wagon!!!!
georgeky
02-10-2008 09:50:37
 Re: SC and dual wheels in reply to glennster, 02-10-2008 04:25:24
Hey Glenn, I been busy. I was crossing the creek to mow another pasture. The old road is in bad shape, and the mower bottomed out on a center ridge. The tractor kept pulling, but the left brake isn't to good so it pulled itself up the bank to the right. I couldn't get the front end back down the bank or that little jewel would have made it.
rich4
02-10-2008 01:35:32
We had a C long time ago, I had thought the SC was a big step up. We had a two row cultivator on the C and it struggled with power and traction even with wheel weights, but cultivated many acres. With smaller tires it would not have pulled as much. Our neighbors SC had no problems in the field. The A series was only rated as a one row cultivator so it should not have struggled. Our C even pulled a two bottom plow on occasion. An A was rated as a one bottom plow. By the way I have seen much larger tractors stuck in the mud. Mowing a swamp is allways a touchy thing. Looks like you got too close to the water.
georgeky
02-10-2008 09:57:31
 Re: SC and dual wheels in reply to rich4, 02-10-2008 01:35:32
Hey Rich, The SC was an improvement over the C. I have overbore pistons in my plain C and it handles a 2 bottom plow anywhere just as well as my SC does. I have plowed many acres in the past with both tractors. I had another C with stock pistons, and it was a bit weaker. Either will do what they were intended to do and then some.
That is an old washed out road crossing the creek, and I have had a couple larger tractors hung in it as well. I fix the hole, and then creek washes it back out the next big rain. The larger tractors are hard to get out of that hole. It stays muddy all the time.
Hugh MacKay
02-10-2008 00:33:00
George: My point is and always has been, every time a manufacturer of engine powered equipment has used a particular engine for more the than one application and two different rated horse power, the engine with the lower rating will always be more successful and have a longer lifespan than the higher rating. I've seen it with IH, I've seen it with Deere and I've seen it with Massey.
Probably one of the biggest differences in load that could be put on an engine was with IH C-113 and C-123 engines. No one can tell me an 11.2x24 tire is going to create as much demand on that little engine as an 11.3x36 tire. It is well known, SA, 100, 130 and 140 have been good for 5,000 hours before rebuild and C, SC, 200 and 230 do well to make 4,000 hours before rebuild. 9 times out of 10 the higher hp engine will have far more wrong with it at rebuild time than the lower hp engine.
Years ago in my hometown we had tractor pulls, whereby the winning criteria was the percentage of load pulled on stone boat in relation to tractor weight. In those days our countryside was loaded with C, SC and 200, probably those 3 accounted for 50% of all tractors. Under those pulling regulations Super A will usually pull close to 3 times it's own weight. A Super H is a close second, Super M will come 3rd and the Super C 4th. The Supers A, H and M will spin out and the SC will die of power. I've seen that hundreds of times. I've experienced it myself with my brothers 230, and no it's not a worn out old tractor, probably amoung the top 10 230s left across North America. I wish my 130 was as well preserved as his 230, but then what could you expect, I doubt if his 230 has seen 2,000 hours since new. I happen to know where it was all those years. My 130 is probably around 12,000 hours
My dad looked at buying a 230 with wide front end, when he bought the 130. I said why would you do that, you already have an H and 300 both nf that will out manuve that 230 any day. We need something short, small, and compact. I know IH sold a lot of C, SC, 200 and 230, personally I could never see it, other than need of a cultivator tractor that size with nf. Plain and simple the Farmalls C, SC, 200 and 230 should have had the C-135 engine.
We've been on this same argument numerous times over the past couple of years. I can tell you, your fast becomming an annoying old fart, and I expect you think the same about me. I'll bet we agree on that. You have a good day George, try hooking the 666 with duals to that mower, it would have the power to roll through that soft spot, quickly.
georgeky
02-10-2008 09:44:06
 Re: SC and dual wheels in reply to Hugh MacKay, 02-10-2008 00:33:00
Hey Hugh, I agree a SC with a C-135 would have been a nice one, but it still doesn't change the fact that it was designed for, and will handle a 2 X 14 inch plow in any ground. I have plowed 100's of acres with them. will pull that plow 10 inches deep in tough KY fescue sod in 2nd gear.
Dad has a 140, and it spins and bucks with the cultivator or 1 bottom plow in the ground deep here. Now I am basing my assesment of each from years of use of each. My SC will spin the tires with weights on it, and the 230 dad had was a bit stronger than my SC is. My point is that you can not run down something based on the very limited experience you have had with it. I used a SA once that wouldn't pull the hat off your head, but that didn't make all of them junk. Have a good one.
Hugh MacKay
02-10-2008 11:13:13
 Re: SC and dual wheels in reply to georgeky, 02-10-2008 09:44:06
George: What Allan doesn't realize, you and I have been calling each other old farts for some time. I do apologize for using the word annoying. We do realize how old we are and do wish we were 20 years old again, these are exciting times. if you and I were 20 years old Allan would think he entered the space age, and realize he's living the past.
I'll openly admit I don't have a lot of personel experience with C, SC, etc. Our country was livestock and grass country. We saw farmers come through the depression with horses, bought a little Ford after the war and used it for car as well as a tractor. In the 50 a degree of prosperiety hit and most of these folks bought a car or pickup and traded the ford tractor off for a C or SC. as a one tractor farm. I could never see that. In 1951 my dad bought an H with 31 loader for $1,650. A Super A was right around $1,000., thus a SC had to be $1,200. Given the fact the 31 loader was probably $200., an H could be had for $150. more than a SC. As I said before, in the mid 50s I'll bet 50% of the tractors in our area were C, SC and 200 on one tractor farms. Those guys were awfully hard on those little tractors. I've seen more C and SC with welded up blocks and front ends than I care to remember. I remember one dairy farmer in particular running 3 C, SC , 200 or 230. He'd put his 75 year old dad on SC with pto driven baler. The old man knew two speeds 2nd gear and faster. He'd tie a baler twine on throttle linkage, supposedly to get him through the tough spots, then drove the SC until it stalled. You'd then see him pulling hay out of the baler and of he'd go again. He keep those tractors 3-4 years and trade them. The dealer told me his tradeins were little more than scrap. No one in farming wanted them. It only stands to reason that little engine aint going to stand 36" tires near as well as 24" tires.
My dad and later myself kept several size tractors around. We didn't cultivate rutabagas with a 1066 or even a 300. We didn't pull a 5 bottom plow with a 130. Didn't even bale hay with the 1066, have baled a few loads with 130. My point is, for those one tractor livestock farms of the 50s, an H was a better buy at roughly $200. more. If you were a two tractor farm, no point in 2 SC. Give me an H and a SA any day. Now George I do realize you were a tobacco farmer and that SC was quite valuable.
Allan In NE
02-10-2008 10:10:06
Wish I had your temperament. :>)
Allan
Allan In NE
02-10-2008 04:04:38
That crack was totally uncalled for and you owe that man an apology.
Allan
Keith-OR
02-10-2008 04:58:37
 Re: SC and dual wheels in reply to Allan In NE, 02-10-2008 04:04:38
Allan, I totally agree!!! Uncalled for!!
But have ya ever seen Hugh admit he is wrong or apologize..:>(
Had a girlfriend like that once. I sold all my manuals, reference books and encylopedias as I didn't need them anymore, because she knew it all..:>)
Keith & Shawn
georgeky
02-10-2008 10:13:05
 Re: SC and dual wheels in reply to Keith-OR, 02-10-2008 04:58:37
Hey Kieth, Shawn, and Allan, I don't pay any attention to Hugh. He is entitled to his opinions same as the rest of us. He has just never used a SC or he would burn those offsets.
It is my opinion for what little it is worth that the SC is the finest little tractor ever made. They can do anything. We used them for years to plow, disk, plant, mow, bale hay, pick corn,grind feed, and on and on. We took care of more than 500 acres with two of them for years. That included 15 acres of tobacco. 40 to 50 acres of corn, 250 to 300 acres of square baled hay, and 100 beef cows. I even hired out to mow hay and cultivate for several neighbors, and plowed many gardens when I was a teenager The only thing we didn't do is fill the silo. We hired a neighbor to do that.
Take care.
Hugh MacKay
02-10-2008 12:38:13
 Re: SC and dual wheels in reply to georgeky, 02-10-2008 10:13:05
George: Did you ever stop to think how much more hay and manure a livestock farm in Canada with 7 months stored feeding and stored manure, would create. It's a lot of tractor work, compared to KY.
I've gone to plow days with my 130 and 2x12 plow, didn't have to take a back seat to any of those SC or 200. Some of them were pulling 2x14 but most had 2x12. I went to a dead weight tractor pull with my SA, no wheel weights or chloride, pulled 7,000#, and they disqualified me because in their opinion my front end came more than 6" off the ground. They didn't bother to tell me about that regulation before hand. None of the 6 SC, 200 and 230, made more than 7,600#. They weren't stopping the H and Cockshutt 30 with 10,000#. For my money, and my farming the C, SC etc. were a non issue. An H was very little more money than a SC, and a SA would fit in a much smaller area than a SC.
georgeky
02-10-2008 21:27:47
 Re: SC and dual wheels in reply to Hugh MacKay, 02-10-2008 12:38:13
Hugh, the SA just will not pull two bottom plow here anywhere. It will pull it in some ground, but not all. This old dirt is tough at best. I have a 2 bottom we tried on dad's 140, and it just wouldn't do it. I am sure it will in Nebraska, and other places where the soil isn't as tough. Thousands of the offsets were sold here, and the great majority with one 14 inch plow.
I have never pulled my C or SC at a tractor pull, but they have worked very hard over the years. I also know some local farmers who could tear up an anvil with a rubber mallet. I have never broken any castings on any of mine. Also keep anti freeze in them so I don't have to patch up my blocks.
ScottyHOMEy
02-10-2008 11:25:47
Please note, y'all, that Hugh took a jab at himself in the very same breath, and opened the door for you to agree.
Hugh MacKay
02-10-2008 12:45:41
 Re: SC and dual wheels in reply to ScottyHOMEy, 02-10-2008 11:25:47
Scotty: That's right, George knows we're both old farts. We both wish we were 20 again, but that ain't going to happen. Aside from that the worst thing I called him was being annoying. He knows I'm annoying, so for Allan's and Keith's part, they both decided to make a mountain out of a mole hill.
135 Fan
02-10-2008 18:43:18
 Re: SC and dual wheels in reply to Hugh MacKay, 02-10-2008 12:45:41
The problem I see with calling anyone a name, even if it's friends calling each other names, is that other people who don't know the relationship you have will start calling people names in the same way. There are a few instances when someone may have to be called out. The political board is gone on here and it seems like the other boards are getting nastier. I always thought the purpose of the forums was to help each other out. I have called a few people out myself because they said insulting comments toward me which I felt were not warranted. If someone disagrees fine. No need to get insulting and arrogant about. It's also OK to agree to disagree. Agreed? Dave
135 Fan
02-10-2008 10:31:54
You can even put duals on a little Ferguson. It shows a picture in the manual. It says for lighter duty work but that's only because of the longer bolts and spacer used on the axle to mount the duals. Dave
georgeky
02-10-2008 11:00:14
 Re: SC and dual wheels in reply to 135 Fan, 02-10-2008 10:31:54
Yep, they relly help for mowing this wet land. Hardly leaves a track at all. That is the only time I put them on my SC. I have had the 666 and 15 foot mower hung up in these bottoms, and takes the dozer to get it out. The SC floats right across it most the time. I woul like to see the little ferguson with duals. I have a TO-30 but no duals for it. Also pull that Ford mower with it. Matter a fact it stays hooked to it most the time. I just use the SC in the bottoms for flotation.
135 Fan
02-10-2008 18:23:09
 Re: SC and dual wheels in reply to georgeky, 02-10-2008 11:00:14
I've seen a lot of hwy. dept. tractors with duals for pulling mowers. Better flotation in soft spots and less compaction. Dave
