Super A crankcase capacity
Lance in Brenha
02-09-2008 21:47:44
How many quarts of oil does a Farmall Super A hold? Thanks
Andy Motteberg
02-10-2008 12:50:21
 Re: Super A crankcase capacity in reply to Lance in Brenham, TX, 02-09-2008 21:47:44
I think it is 5 quarts. Did you ever get that Farmall A for $550 you talked about a while back?
02-10-2008 21:03:15
 Re: Super A crankcase capacity in reply to Andy Motteberg, 02-10-2008 12:50:21
yep, this is the one
Dave BN
02-10-2008 10:45:58
Assuming you have the oil pan with 2 petcocks, you should fill it until oil comes out the top petcock. 5 qts sound right. If you are new to tractors or to this tractor there is lots you should know and you should get an operators manual. It will help you in servicing your tractor. One thing you should know if you don't is that the oil in the air cleaner should be changed when you change your engine oil. Unscrew the thumb screw that holds the cup onto the bottom of the air cleaner, dump the old oil out and wipe the cup clean. Refill the cup with engine oil to the full line stamped into the cup. Dave.
old
02-09-2008 21:55:59
As per the I-T manual 5qts.
02-09-2008 22:16:57
 Re: Super A crankcase capacity in reply to old, 02-09-2008 21:55:59
Thanks old!
