986 inj pump
rls_ia
02-10-2008 06:58:05
Will a injection pump off a 1086 fit a 986? I know the 986 has a 436 and the 1086 has a 414. I didn't know it the would fit both.
Thanks, Bob
RIVIR
02-10-2008 13:12:39
 Re: 986 inj pump in reply to rls_ia, 02-10-2008 06:58:05
I will tell you what have done , is that i put a fuel pump off an 915 IHC SP combine and i dont see any difference in fuel consumption from my other two 986's and the 915 is a turbo engine. i never had nothing adjusted just leave it alone if its workin, the 915 engine fuel pump has a electric fuel shut off which i think is a plus.
rls_ia
02-10-2008 13:05:57
Thanks for the replies, I thought it would work but wasn't sure.
Bob
Joe Schmitt
02-10-2008 10:25:36
Your 986 should have a 436 non Turbo and 1086 has a 414 Turbo . The pumps are interchangeable however the 986 pump if stock should have a 9mm plunger in the hyd. head of the pumpand the 1086 should have a 10mm . All this mean is the 1086 pump will probably put out more fuel. You can back the fuel down on a 10mm pump to be very close to a 9mm. I would put the 1086 pump on and try it just how it is.You can change the fuel setting with the pump on the engine.
I.H. parking only
02-10-2008 07:32:52
I could be wrong, but I think both the 986, and the 1086 have the 414, but the 1086 is turbo charged. I know that is the case with the 966, and 1066. That being said I think the injector pump would be interchangable. Jon
IaGary
02-10-2008 11:44:49
 Re: 986 inj pump in reply to I.H. parking only, 02-10-2008 07:32:52
No joe is right IH, the 986 did have 436 non turboed.
And you are right the 966 did have the 414.
1066 and 1086 have the 414 with a turbo.
1486 has the 436 with a turbo.
