Snow Plow
Dave S.
02-10-2008 08:55:44
Has anyone mounted a snow plow with the self contained 12 volt hydraulic system off of a pickup on a H, M or any other tractor and how did it work or will it work. Dave
Brian J
02-11-2008 08:54:02
 Re: Snow Plow in reply to Dave S., 02-10-2008 08:55:44
I hooked a western Pump, plow and controls to my Massey 245. It works great until the snow gets really heavy, then I need more weight. Fabricating a plow frame/bracket would be the hardest part.
RayP(MI)
02-10-2008 14:00:58
I have a Monarch electric lift on my PU snowplow. The motor on it is about the size of a smaller car starter. If you use it a bunch, the alternator will work pretty hard to keep up. Last time I got my alternator worked on, I got a 100 amp unit. Many times that alternator belt is squalling trying to keep up with the alternator load. All in all, the system works very well, but the point is that you have to have a good charging system capable of many amps to keep up. (My truck has dual batteries, and your tractor probably only has one.)
Bill Geer
02-10-2008 10:30:55
I have that set up on my h. It works fine, but I have a alt not a gen. I do not use the lites. If you need to work at night you may drain the battery. Bill
