one more thing
glennster
02-10-2008 10:10:57
opps forgot to mention, be sure to check the valves to be sure they will open before you put the valve cover back on. if they are stuck, they will bend your new push rods. soak em up with pb blaster, trans fuid, kerosene, then turn the motor over by hand and see if the valves open. if not, you gotta get em loose first, otherwise you will trash your new push rods.
