Opinion need on 39 M prodject
Paul G. in Mn
02-10-2008 15:19:34
I am going to be finishing up the restoreation on my really low serial number M (#529)this spring and am trying to decide if I should keep the wide front. I have a really nice steal tube one with the tie rods out front. I like the looks and the way it drives with the wide front but trying to get most everything else correct to the tractor. If leave the front Id also add fenders and the glass air cleaner. If this were your tractor how would you set it up? I also have a 39 H with the same style wide front I thought Id make into a matching pair....thanks Paul
Farmall Freak
02-11-2008 14:29:42
 Re: Opinion need on 39 M prodject in reply to Paul G. in Mn, 02-10-2008 15:19:34
Personally I would keep the tractor stock, but you could put on your other front end and keep the one that is on it just to keep with the tractor in case you ever want it to be matching numbers.
kossuth
02-10-2008 17:02:12
 Re: Opinion need on 39 M prodject in reply to CNKS, 02-10-2008 15:19:34
Do with it as you wish. Now if you know of some of the history of the machine then some abnormalities of the machine give it character and some history thus I wouldn't change them. Like my dad's 51 M. If I ever restore that machine it will never have fenders on it, because they were a PITA to mount and remount when you wanted to put the cultivator on the machine so once they came off they never went back on. It will also keep the older style clamp stle hubs and wheels vs the original 3 bolt hubs. Why??? Because there is a story about how and why that unit got there LOL.
39 AND HOLDEN
02-10-2008 16:34:27
Paul,
I like the bell's and whistle's, yes to the wide front, fenders, and accessory's. I see you have 1939's, M, H, F-20 more? Gotta love your serial # I have said that before.
I too love 1939's I have two 1939 H's 1939 F-20 w/ elec. start, fenders, lights, O/D, etc. and a 1939 Buick coupe. I try to put all the accessorys I can find on them. They made so many M, H, F-20's it helps them to stand out being dressed up.
39 and holden anything 39
Paul G. in Mn
02-10-2008 16:41:01
 Re: Opinion need on 39 M prodject in reply to 39 AND HOLDEN, 02-10-2008 16:34:27
yeah I like the 39's I have this M and have a H thats a higher serial number and the f-20 that about 600 from the last one that has electric start as well. Looking one day for a 39 f-30, f-14, A and B and..... sounds like you have a nice collection too love to see pictures sometime. Paul
Andy Motteberg
02-10-2008 16:23:31
If it was mine, I'd use the wide front end with the rods out front.
Andy.
Mike Androvich
02-10-2008 16:12:00
Don't mean to sidetrack your thread, but I just looked at M #530 yesterday, so hearing about yours is quite a coincidence. Does yours have the serial plate on the bell housing? #530 does not and never did.
Paul G. in Mn
02-10-2008 16:18:15
 Re: Opinion need on 39 M prodject in reply to Mike Androvich, 02-10-2008 16:12:00
no mine does not have a serial tag and never did obly stamped on the frame rail and engine...Were is 530 located if I may ask..Would love to see some casting numbers and pictures my e-mail is open. Paul
Janicholson
02-10-2008 15:37:27
Leaving them on is just fine. It is cosmetic, common practice and is just the thing owners do to tractors. You aren't putting a 60s SAAB 3 cylinder 2 stroke in it. JimN
Andrew Z
02-10-2008 15:24:10
Whyyyy not keep it a wide front?
Andrew
