1950 Farmall H leaking hydraulic oil
DickelDawg
02-11-2008 07:45:25
Need help with 1950 Farmall H. Was plowing snow the other day when I noticed I was leaving a trail of oil. Hydraulic oil is leaking from under the center of the tractor out from under what I think is the lift-all dust pan. I am no mechanic although I do small automotive jobs like changing brake shoes, and the usual maintenance jobs. Can someone please help me out with what I need to do first!
Thanks
DickelDawg
02-11-2008 08:32:02
 Re: 1950 Farmall H leaking hydraulic oil in reply to DickelDawg, 02-11-2008 07:45:25
Thanks, Michael. As soon as the weather gets a little better I'll drop that pan and see what it looks like.
Thanks again,
Skip
Michael Soldan
02-11-2008 08:23:34
You need to remove that inspection plate under the belly pump and try to asertain where the leak is coming from, a line, a fitting or the shaft seal that drives the pump. If it is a shaft seal the pump needs to be removed so you can change it..not that hard a job if you feel limited in your mechanical ability but getting the pump out needs another helper or a support jack stand. The shaft seal has a flange that turns off, pick out the old seal and install a new one, replace the flange and then reassemble pump..there are other scenarios that could be in there as well, you'll have a better idea when you get a good look.
