Long Time Question on Super M
Tom43
02-11-2008 08:46:01
Dear Forum'
Several years ago I overhauled a Super M for a neighbor. I even had the timing case off to replace the front seal on the crankshaft. Cam to crank timing marks were all ok. When I was all done the tractor ran great but I thought I would put a timing light on it to fine tune it. To my great surprise the marks on the pointer were way off and when set correctly the tractor would barely run. This puzzle has bothered me for years as the front pully is solid unlike harmonic balancers and was propery keyed to the crankshaft. as I said, the tractor ran great but not where it was supposed to. I hope some of the Farmall experts will respond.
Chuck's Repair
02-11-2008 15:20:28
 Re: Long Time Question on Super M in reply to Tom43, 02-11-2008 08:46:01
The distributer shaft plate that holds the weights has a number stamped on it.That number is the maximum degrees that that distributer will advance.
Chuck
karl f
02-11-2008 12:22:55
i think the specs for the distributor begin to list a small amount of advance at only 250 rpm. i believe that it's in distributor rpm (double for crank), have to look. also i think there were a couple different pulleys with a different number of marks...it's possible you looked at the right info for the wrong pulley and the result is about 15 degrees off. there may be other pulleys that fit than the 2 originally optioned for the engine, adding to more marking confusion. plus could be the "wrong" or field changed over distributor. question for others: what changes did the firecrater kit do to the advance timing curve?
karl f
Janicholson
02-11-2008 08:51:50
As easy as pie:
The timing mark is static timing for the point opening when at cranking speed (or hand cranking) It is TDC. The timing with a light requires a degree wheel or Geometric calculation of circumferential distance to mark the correct location of the timing when running (they have advance mechanism) Magneto systems in Farmalls do not have advance mechanisms except the impulse coup[ling, so they are fuill advance upon starting. JimN
Andy Martin
02-11-2008 08:51:30
The timing marks are set for static timing.
With the tractor running you have to accomodate the centrifugal advance and put a new timing mark on the harmonic balancer to get it timed right. But why use a timing light when the engine was designed, and works well, with static timing?
Tom43
02-11-2008 09:26:55
 Re: Long Time Question on Super M in reply to Andy Martin, 02-11-2008 08:51:30
Thank you both for the prompt replys. However, the tractor had a distributor not a magneto and I was idling the tractor very slowly in order not to get any centrifugal advance The advance mechanism in the distributor was working properly with no broken springs etc. Running timing at full throttle on a Super M is supposed to be 35 degrees at full throttle and this was way off also. I measured the circumference of the front pulley and marked off 35 degrees from the static timing mark. I am still baffled.
ScottyHOMEy
02-11-2008 10:55:38
 Re: Long Time Question on Super M in reply to Tom43, 02-11-2008 09:26:55
I don't mean this as an insult. Did you measure off the 35* in the right driection? You say "way off" but not how far or in which direction.
Tom 43
02-11-2008 11:50:28
 Re: Long Time Question on Super M in reply to ScottyHOMEy, 02-11-2008 10:55:38
Thanks for the reply. I was wrong on the number of degrees for full advance as it should be 30 degrees instead of 35 as I stated. Looking at the pulley from the front of the tractor I measured 30 degrees clockwise from the timing mark which would be 30 degrees BTDC. It seems that it was still quite a bit more advanced than this. The main thing I remember is the tractor being 40 or 50 degrees advanced at very slow idle. specifications call for a maximum advance of 9 degrees at 800rpm and I was probably at 400 rpm.
ScottyHOMEy
02-11-2008 12:50:57
 Re: Long Time Question on Super M in reply to Tom 43, 02-11-2008 11:50:28
This is a gas engine, right? If so which direction is your timing off in?
The tables I'm looking at (from IT-8) show 0* up to 200 RPM for a Super M gasser, 4.5* advance at 400, 12* at 600, reaching a full advance of 15* at 800
Tom43
02-11-2008 13:34:45
 Re: Long Time Question on Super M in reply to ScottyHOMEy, 02-11-2008 12:50:57
Dear Scotty,
That is the same table I am using, but you must remember those are distributor degrees which must be doubled for crankshaft degrees.
ScottyHOMEy
02-11-2008 13:49:13
 Re: Long Time Question on Super M in reply to Tom43, 02-11-2008 13:34:45
Touche'! (Note to self: Read the header on the chart, Taylor!)
So which direction are you off? And by eyeball, how many degrees?
