I H hi trans suppliment??
tooltime
02-11-2008 15:42:16
MY 340 UTILITY POWER STEERING GEAR BOX CALLS FOR IH HI TRANS OIL SUPPLIMENT TO BE USED, ABOUT 1 AND 3/4 PINT TO FILL GEAR BOX TO TOP OF FILL PLUG ON STEERING UNIT. IS THIS MAYBE THE SAME AS REGULAR 80-90 WT GEAR OIL. THANKS, JIM
Mark W.
02-12-2008 10:03:33
 Re: I H hi trans suppliment?? in reply to tooltime, 02-11-2008 15:42:16
Did you rebuild your power steering unit? I have a 340 utility that I was thinking of replacing seals and gaskets but wasn't sure how readily available parts were.
Bob
02-11-2008 19:53:40
In the old days (when the book was printed) an oil supplement was needed.
Nowadays, Hytran is all you need.
GA Dave
02-11-2008 19:00:29
 Re: I H hi trans suppliment?? in reply to Red Mist, 02-11-2008 15:42:16
Hy-Tran is hydraulic and transmission fluid. Do not use the 90 wt. Any supplier should have something that is close. David.
dave guest
02-11-2008 18:18:48
I think what you are talking about is closer to automatic trans fluid. You did say power steering. I think 80-90 would blow a seal. Check with someone who knows for sure.
