4.125 piston
LN
02-11-2008 18:50:05
I'm rebuilding a farmall M several people have told me that they put 4.125 pistons in these. I know that was the size that was in my MTA I have the M apart and with sleeve out the block measures 4.125 is there enough material to machine the block to accomodate a larger sleeve.
Red Mist
02-12-2008 05:18:07
 Re: 4.125 piston in reply to LN, 02-11-2008 18:50:05
An M was originally 3.875". You can get a 4.00" sleeve and piston kit. Sure would be easier and less expensive to stop there, unless you can find a SM/400 or even 450 block. mike
Charles E. McNelly III
02-11-2008 19:00:57
Cut away material just to add material? Hone the block and run the pistons that way, others do it. Charles
LN
02-11-2008 19:17:54
 Re: 4.125 piston in reply to Charles E. McNelly III, 02-11-2008 19:00:57
what would I do with the step at top of block where the sleeve sets
02-12-2008 16:44:54
 Re: 4.125 piston in reply to LN, 02-11-2008 19:17:54
Call some shops that are mentioned on this forum, they have them. Good Luck,
Charles
VOLfarmall
02-12-2008 02:50:38
You have to have a machine shop make you 4 rings for the top of the block to seal the head gasket,
