FARMALL Headlight Connectors?
Charles Todd
02-11-2008 21:14:17
Has anyone replaced their headlight plugs? Mine have endured 45 years of the hot, brutal Texas and Louisiana sun. They have fell apart. I am thinking of replacing them with standard rubber tractor lights, but the IH steel lights are darn cute. I recently purchased the TC-88 Parts Catalog and it doesen't seem to list just the plug, but rather a wiring harness (most likely discontinued or cost me my first born male child). Anyone else in the same boat?
Dave Sherburne NY
02-12-2008 10:28:42
 Re: FARMALL Headlight Connectors? in reply to Charles Todd, 02-11-2008 21:14:17
If you are talking about the plug that goes thru
the teardrop shaped lite, screw on the inside, and
screw on the outside, Try a John Deere dealer.
I tried to find then at JD parts, but they don.t
list any tractors before the New Generation tractors
El Toro
02-12-2008 05:51:33
I would use crimp on connectors to make the light connections. Hal
glennster
02-12-2008 05:49:48
oem tractor parts have all the goodies available to rebuild your headlamps.
VA Gasman
02-12-2008 03:54:21
Added an oliver this past summer to my collection. I found 6V sealed beams at tractor supply that fit the lite housing. So i just took out and saved the original bulb and internal parts and wired in the sealed beam . Looks great. My A looks like it has the same size housing.
