Low speed 1st gear for M, looking for info
CenTexFarmall
02-11-2008 22:27:09
I've pretty much decided to make the extra M I have into a chore tractor and put the loader on it. I'm thinking about putting the low 1st gear setup in it.
Does anyone know where I can find the info on what the speed actually is with low 1st? I'm wondering how it compares to regular 1st. Also is it hard to find that setup? Is it just a dumb idea?
RichH
02-12-2008 19:25:23
 Re: Low speed 1st gear for M, looking for info in reply to CenTexFarmall, 02-11-2008 22:27:09
Certain W-6 serial numbered tractors will match up with M"s and puting the W-6 gears and counter shafts will slow an M down about .5 mph at full rpm. Did that to my stock puller M and have no problem with mph at stock pulls.
CenTexFarmall
02-13-2008 21:37:42
 Re: Low speed 1st gear for M, looking for info in reply to RichH, 02-12-2008 19:25:23
That's a good tip and something I did not know.
Thanks.
karl f
02-12-2008 15:58:19
 Re: Low speed 1st gear for M, looking for info in reply to kwm219, 02-11-2008 22:27:09
CenTexFarmall said: (quoted from post at 12:44:56 02/12/08) I could see how it would be impractical for a field tractor. I think it could be useful for me in some situations on a chore tractor.
i would say it depends on your needs. often i've found i've needed slower speeds than available in the field and faster than available in the yard, or the other way around--even with an 8 fwd 2 reverse speeds tranny (ford). A good M will have enough power at lower engine rpm (and resulting lower ground speeds) to do quite a bit of hard yard work before you need to open 'er up.
karl f
superih
02-12-2008 10:37:35
Farmall M 1760 rpms, 14.9-38 tire, standard 1st= 3.41 mph, low-low first= 2.26 mph.
1. low-low gears are hard to find
2. You will need to change out the counter shaft, reverse idler, and 1st gear slider, that should be it.
CenTexFarmall
02-12-2008 11:52:47
 Re: Low speed 1st gear for M, looking for info in reply to superih, 02-12-2008 10:37:35
Thanks.
I was trying to find this data, the actual mph speeds but hadn't. Where did you find it?
superih
02-13-2008 06:29:33
 Re: Low speed 1st gear for M, looking for info in reply to CenTexFarmall, 02-12-2008 11:52:47
I calculate it with the gear ratio's and tire rolling circumference.
Andrew Z
02-12-2008 08:48:39
I dont know if you want the low gear in there, its really low... compared to regular 1st. We have one in a Super H and when that thing is screming at 2000 rpms it hardly moves... Great for pulling but when using the tractor in the feild we never use it.
Andrew
CenTexFarmall
02-12-2008 11:44:56
 Re: Low speed 1st gear for M, looking for info in reply to Andrew Z, 02-12-2008 08:48:39
Haas
02-12-2008 06:45:20
There is a low speed 1st setup for the M. I don't know what speed it gives you. It is a pretty major job to install it and the parts are not easy to come by. I think orchard tractors O-6 had this as standard equipment and parts may fit the M. You have to change out the counter shaft and the reverse gears as well as the second gear on the countershaft, maybe others. The first gear on the countershaft is too small to make a gear to slide onto the shaft, so the gear is machined into the shaft. That is why you must change the countershaft. The reverse idler runs off 1st gear, so you have to change that. In the standard set up, the 1st and 2nd gear on the counter shaft is made together as a double gear, so since the 1st gear is on the countershaft with the new setup, you have to put in a single gear for 2nd. Bottom line is you have to take nearly everything out of the transmission to do it if you can even find the parts.
CenTexFarmall
02-12-2008 10:21:03
 Re: Low speed 1st gear for M, looking for info in reply to Haas, 02-12-2008 06:45:20
I know it requires dismantling the transmission.
Have you done one of these conversions before?
Haas
02-12-2008 18:02:26
 Re: Low speed 1st gear for M, looking for info in reply to CenTexFarmall, 02-12-2008 10:21:03
No have not done it. I just looked in my parts info to find the conversion set up.
