Farmall H dual fuel manifold question
Tom Fleming
02-12-2008 02:44:02
I am restoring a 1942 Farmall H. It has been modified in a couple of places. I believe it to originally a dual fuel model, as the hood has the extra hole for the starter tank.
Does anyone have a picture of the dual fuel manifold for the H? Was there such a thing? I would like to put this back to original if I can, and wanted to verify whether or not I have the right manifold (as many things on this H have been changed).
Michael Soldan
02-12-2008 05:14:36
 Re: Farmall H dual fuel manifold question in reply to Tom Fleming, 02-12-2008 02:44:02
There is also a metal shroud that fir over the entire manifold to hold the heat in, this made the kerosene burn more efficiently. I have two H's, one set up for dual fuel (The original kerosene is no longer available)..after repairing the dual fuel manifold on one, I opted for a new gas manifold for the other..no comparison, new manifold works much better, distributes better and has a better flow making twice the tractor the other one is, Iknow you want to restore as original but the original fuel isn't made anymore
RustyFarmall
02-12-2008 04:42:43
IH Farmall did not call it a dual fuel as such, but most likely your H did originally start on gasoline and then was manually changed over to run on kerosene or distillate. The intake/exhaust manifold was/is different, and easily recognized because the exhaust pipe, instead of screwing into the manifold, had a slightly oval shape at the bottom and was bolted to the manifold.
