Order Farmall Cub Parts Online
EBAY CUB HIGH AND WIDE
WHAT THE %%%
02-12-2008 18:35:42
There is a Cub on ebay that is wider and higher than any I have ever seen. Is it factory or homemade? ebay item 320217013382
mkirsch
02-13-2008 11:53:24
 Re: EBAY CUB HIGH AND WIDE in reply to tooltime, 02-12-2008 18:35:42
It looks to be a '59-'63 model by the oval "Cub" emblems on the hood doglegs. That deluxe seat and bent-over shift lever COULD be correct for that age of Cub.
If my theory holds, then what is incorrect is the grille. It should be a 4-bar grille, not a mesh grille. Also, the decals are wrong.
Exhaust is definitely wrong. While that tractor may have had the underslung exhaust, it would've been underslung. This exhaust runs back over the top of the rear axle...
Neat idea how they bolted two axle housings together on the right. Wonder how they did the shaft.
WHAT THE %%%
02-13-2008 14:59:23
 Re: EBAY CUB HIGH AND WIDE in reply to mkirsch, 02-13-2008 11:53:24
If that seat frame was green it would look exactly like the one on my late model B John Deere.
Tractorfan1
02-13-2008 07:28:25
 Re: EBAY CUB HIGH AND WIDE in reply to WHAT THE %%%, 02-12-2008 18:35:42
That cub is all home made. The seat is not correct. It should have the vertical exhaust. Either the rear end has been replaced or they have the wrong shift lever on it... :?
jakee
02-12-2008 20:06:17
yes they made one called a HI-WIDE crop, very rarer, had one but dont think it was that wide
Nat 2
02-12-2008 19:35:22
 Re: EBAY CUB HIGH AND WIDE in reply to Doug C., 02-12-2008 18:35:42
That is definitely homemade, at least the wide part. Notice that there are a total of three right-hand axle housings... Two are welded together on the right, and one is installed on the left.
In the pictures, it looks like a masterful job.
WHAT THE %%
02-12-2008 20:23:05
 Re: EBAY CUB HIGH AND WIDE in reply to Nat 2, 02-12-2008 19:35:22
I blowed up the photos on ebay and you are correct about the axle housings spacings, But they are bolted together not welded. I have seen a (B) widen out bolting a R/H axle housing to to L/H side. I talked to the man that done it. The axle had to be lenghtened, But the housing bolted right on with no mods. He should have listed it as a High Crop experimental that would have got it over $10,000 for sure. Ha Ha
gots-2-go
02-12-2008 19:43:34
 Pictures of it in reply to Nat 2, 02-12-2008 19:35:22
Side View
Rear View
