Dont know why youd want to put a 2 row set of cultivators on
Farmallb
02-12-2008 18:45:56
A M, but like said, theyll fit, M used 4 row cults, I never saw a M cultivating, but that was a LONG time ago, when farmers thought different, and the smaller tractors was used for cultivating in NE Kans.
NDS
02-13-2008 12:25:56
 Re: Dont know why youd want to put a 2 row set of cultivator in reply to Farmallb, 02-12-2008 18:45:56
In my area Ms and A JDs were the most common tractors and I never saw a 4 row cultivator until fiftys and by then Ms had been in production for 15 years or so. Before we went to later model diesel tractors we were running 4 row front mounts on M and SM and 4 row front mount on G JD. In fiftys we were not far from days of mule cultivators and 2 rows were a great improvement.
olderguy
02-13-2008 08:16:02
Farmallb, Back in the fifties we planted corn with a J. D. 2 row planter so the 2 row cultivator was used on our M. Also, we only had the one tractor at that time, it had to do it all.
Hugh MacKay
02-13-2008 08:08:17
Go to potato country if you want to see why they built a 2 row cultivator for an M. An H wont handle the job very well. Those boys are trying to loosen enough soil to keep the potato crop covered. I once bought a has been potato farm, in the early days they used a wide gauge crawler on two 36" rows. Later he went to a Massey Harris GP, 4x4 had the traction but lacked power for speed. In 1967 he bought a new 656 and 504, put a 2000 loader on the 656, planned on using it for plowing, diskig, etc. He bought a 2 row cultivator for the 504, center mount and rear tool bar. One year later the 2000 loader was on the 504 and the 2 row cultivators were on the 656, he said the 504 just wouldn't handle the 2 row cultivator. He said under some conditions it could give the 656 traction problems.
I've been to PEI, potato capital of Canada, watched them using 4 row on 856, 1256, 966 and 1066. I'm sure they were loading those tractors. In fact I've never seen folks make a tractor look old any faster than PE Islanders. Man those guys could beat a tractor to death in a hurry.
John M
02-13-2008 03:47:45
We had a set of 4 row cults on our M. I dont recall the model, but we took them off of a 400 and set them right on the M.
John in Ne.
02-13-2008 02:57:22
I've only seen a couple of store bought 4 row mounted cultivators for an H or a M.Most I've seen were made out of two 2 row units welded together.John.
georgeky
02-13-2008 21:45:56
 Re: Dont know why youd want to put a 2 row set of cultivator in reply to John in Ne., 02-13-2008 02:57:22
Maybe my store bought 4 row cultivator is a collectors item. I figured there were lots of them in corn country. I bought this set at an auction 15 years ago, with original paint and decals still on them. Birds roosted over them one winter, and destoyed the nice red and blue.
dhermesc
02-13-2008 14:11:33
"I've only seen a couple of store bought 4 row mounted cultivators for an H or a M.Most I've seen were made out of two 2 row units welded together.John."
Agreed,
I had also seen a lot of 2 rows welded up to make 4 rows - then welded again to make 6 row cultivators. Seemed like dad had half the steel from a windmill used to brace up the cultivator frames.
georgeky
02-12-2008 22:35:32
Maybe he has a 2 row planter. Hard to plow 4 rows planted 2 at a time. Many sets of 2 rows were sold with M's.
Janicholson
02-13-2008 05:54:28
 Re: Dont know why youd want to put a 2 row set of cultivator in reply to georgeky, 02-12-2008 22:35:32
Georgeky. you are exactly correct. The use of a four row cultivator on a field planted with a two row planter devistated the rows not being watched. Even pretty flat fields were not perfect between the planter stripes. When driving a 2 row it was very obvious when the operator started down the rows with one set of shields on a different planter track than the other (OOPS). JimN
john *.?-!.* cub owner
02-12-2008 19:47:03
not much cultivating done in this area, but in the hills with terraces and small fields, most tractors used 2 row cultivators rather than 4 row. fuel was not very expensive, and you did not waste as much ground.
LA in Wi.
02-12-2008 21:07:47
 Saw a quite a few M with 2 row cults. in reply to john *.?-!.* cub owner, 02-12-2008 19:47:03
I saw a lot of M Farmalls with 2-row cultivators in Iowa back in the early 1950s. 4-row stuff came along in the late 1950s when farmers starting farming "big acres"....up to 240 acres instead of 160.
Dan Henebry
02-13-2008 15:25:27
 Re: Saw a quite a few M with 2 row cults. in reply to LA in Wi., 02-12-2008 21:07:47
I remember in the late 70's when 16 row cultivators were beginning to be used and my mom's dad was talking about when they switched from 2 to 4 row cultivators. He said alot of farmers couldn't see how you could do a good job cultivating trying to watch all 4 of those rows instead of two. I would say the 4 row cultivators followed the 4 row planter so when they came out the 4 row cultivator probably wasn't far behind.
