A, SA, 100 15 steer rim
couv
02-12-2008 19:16:43
Anyone know of a 15 inch standard width rim that will bolt up to an A, SA, 100, 130, 140 ? I have a front dirt blade, and the 4.00 x 19 tires just cut ruts in fresh dirt you are spreading. If I could put a 7.00 x 15 (or so), the front end weight would be spread in a wider footprint, and not rut up the dirt work so badly.
Steve
Hugh MacKay
02-13-2008 04:06:20
 Re: A, SA, 100 15 steer rim in reply to couv, 02-12-2008 19:16:43
Steve: I have a set of 6.50x16 fron tires on my 130. Back when these tractors were new 4x16 rims were an option, usually they installed 5.50x16 tires front and 11.2x24 on back. You cant buy 16" replacment rims for the cast wheels anymore. They are still available for 140s with disc wheel.
My 130 had 16" wheels when new. To replace them I got 4.5x16 blank rims, made up 1/2" x 1-1/2" steel bands to weld inside the rim. That will fit snugly over the cast center, I then welded on lugs for bolting rim to the wheel. I wouldn't be without my 6.50x15 with front mounted blade, makes a huge difference. To make one of these tractor sit level with 6.50x15 you need 12.4x24 on rear.
tn terry t
02-12-2008 21:30:36
wasnt thinking AV's :)
gene bender
02-12-2008 20:39:53
The rims you now have have the three places where they bolt to the center correct. You need the 3x15 standard rim for the regular A. Now going to the 15in wont be a problem for your blade set-up. You can grind the center out of any 15in rim that will fit over the cast centers then weld three brackets to match. What size tires do you want to run. I have rims that will bolt on.
tn terry t
02-12-2008 19:41:45
 Re: A, SA, 100 15 steer rim in reply to Duner Wi, 02-12-2008 19:16:43
couv said: (quoted from post at 20:16:43 02/12/08) Anyone know of a 15 inch standard width rim that will bolt up to an A, SA, 100, 130, 140 ? I have a front dirt blade, and the 4.00 x 19 tires just cut ruts in fresh dirt you are spreading. If I could put a 7.00 x 15 (or so), the front end weight would be spread in a wider footprint, and not rut up the dirt work so badly.
Steve
thats a new one on me never hears of a 4.00x19 i have three of these tractors i have 6.00 x15 on all of them and they are stock rims you can get those bout anywhere
Vacherie
02-12-2008 20:13:57
 Re: A, SA, 100 15 steer rim in reply to tn terry t, 02-12-2008 19:41:45
I have 4:00 X 19 on the front of my Super AV.
