engine block and fuel tank
delawhere
02-13-2008 02:44:15
wanting to flush out both engine block and fuel tank. whats a good chemical for each. thanks.
Red Mist
02-13-2008 05:30:00
 Re: engine block and fuel tank in reply to delawhere, 02-13-2008 02:44:15
Carb cleaner is excellent for dirt, sludge, varnish, residue in a fuel tank. You can buy it in a 5 gallon container. mike
El Toro
02-13-2008 05:06:46
Have your local auto machine shop to clean the block and all the oil passages. Check with your
local radiator shop to see if they clean gas tanks. Hal
delawhere
02-13-2008 07:08:12
 Re: engine block and fuel tank in reply to El Toro, 02-13-2008 05:06:46
sorry for misleading. i just want to run a good cleaner through the motor while its running. thanks.
