Ignition Coil Wiring
Duane Eckelman
02-13-2008 17:24:38
I am converting my M to a 12 volt system. How do I hook up the coil to the distributor. Does it hook to the positive or negative side of the coil to the distributor. Our battery is negative ground with an alternator.
John T
02-14-2008 08:29:30
 Re: Ignition Coil Wiring in reply to Duane Eckelman, 02-13-2008 17:24:38
As posted, simply match the coil to whichever ground you have i.e. if at Neg ground the coils -wires to distributor and its + receives Ignition Switch voltage. It can still produce a spark if wired wrong but its more efficient if wired correctly..... .
John T
Owen Aaland
02-14-2008 02:07:53
Connect the + terminal to the positive side of the battery and the - terminal to the negative side of the battery.
In a negative ground system the - terminal goes to the points. If you have a positive grounded system the + terminal goes to the points.
Will Sickm
02-13-2008 19:33:42
Sorry, I looked again and I was wrong.
Will Sickm
02-13-2008 19:30:39
The way this diagram is it wont show discharge when the lights or ignition are on.
Jossette
02-13-2008 18:48:11
third party image
hgf
Allan In NE
02-13-2008 17:29:13
Negative to the points.
Allan
Bob
02-13-2008 17:32:15
 Re: Ignition Coil Wiring in reply to Allan In NE, 02-13-2008 17:29:13
Also, be SURE it's a "true" 12-volt coil, or if it's NOT, be SURE you are using the correct ballast resistor with it.
