Heisler 9 speed
Eric Gady
02-14-2008 08:14:22
I have a 47 M with the aftermarket heisler 9 speed in it. just wondering since the pto will spin faster when the 9 speed is in high range will it put any type of significant change on horse power rating it will put out? but i have also heard it that not many implements could handle this high rpm.
r4etired
02-14-2008 17:31:29
 Re: Heisler 9 speed in reply to Eric Gady, 02-14-2008 08:14:22
The belly pump also will run at a faster speed. It's not a problem.but they recomend that you use the hydraulics only in direct.
Janicholson
02-14-2008 08:54:12
Measure the RPM It is higher than 1000 I think That unless Idled down, and kept under control that using it is a vvvveeeerrrryyy bad idea. An exploded gearbox, or rotary mower will kill instantly. JimN
