seals and parts for 656/ 263 gas/ std 5 speed/1966
Jerry Gilliam
02-14-2008 14:03:48
Does anyone know if I will be able the get the seals or parts for my TA after getting it torn down. I can't use shop space for a long time.If anyone has had experience in the buying of seals and etc for TA lately, let me know where to look and buy. Thanks in Advance
Jerry
mkirsch
02-15-2008 06:41:04
 Re: seals and parts for 656/ 263 gas/ std 5 speed/1966 in reply to old, 02-14-2008 14:03:48
Just thought of another source, Leahman (or Lehman) Tractor Parts down in Pennsylvania. I believe they're the ones that sell the "mechanical diode" TA units, which are supposed to be better than remans.
mkirsch
02-14-2008 15:01:34
 Re: seals and parts for 656/ 263 gas/ std 5 speed/1966 in reply to Wesley Stephens, 02-14-2008 14:03:48
Your local CaseIH dealer may not be the least expensive, but they will be able to look up the parts easily and usually have them in stock. Otherwise you could spend months chasing after cross-referenced seals, and still never find the gaskets anywhere else...
Jerry Gilliam
02-14-2008 16:23:50
 Re: seals and parts for 656/ 263 gas/ std 5 speed/1966 in reply to mkirsch, 02-14-2008 15:01:34
Thanks I'll go there
K.B.-826
02-14-2008 17:03:19
 Re: seals and parts for 656/ 263 gas/ std 5 speed/1966 in reply to Jerry Gilliam, 02-14-2008 16:23:50
Most of the aftermarket TA remanufacturers offer a seal/gasket kit that includes everything you'd need. Comes with all of the seals for the TA and all of the gaskets for the various covers on the clutch housing, and the gasket and o-ring between the trans housing and clutch housing.
Jerry Gilliam
02-14-2008 20:23:57
 Re: seals and parts for 656/ 263 gas/ std 5 speed/1966 in reply to K.B.-826, 02-14-2008 17:03:19
Would happen to know the name and location of a couple I could call and order
Thanks
Jerry
K.B.-826
02-14-2008 22:06:14
 Re: seals and parts for 656/ 263 gas/ std 5 speed/1966 in reply to Jerry Gilliam, 02-14-2008 20:23:57
Hy-Capacity is about the best. I've had very good luck with their parts. Web site is www . hy-capacity . com. I don't know if you can order directly off of their web site, around here few of the small independent farm equipment shops are dealers for them, as well as the local Case-IH dealer. Another remanufacturer is called Ag Parts. I installed a complete reman TA from them in a 666 this summer. First one they sent had a tight spot in the planetary when turned by hand after being bolted into the housing. Second one they sent was fine. Made the mistake of going back to them for the TA for my 544. First one had a noise after it was installed, second one turned hard, third one we put together from new parts. I've had no problems with anything from them other than the planetary parts.
Jerry Gilliam
02-15-2008 05:40:01
 Re: seals and parts for 656/ 263 gas/ std 5 speed/1966 in reply to K.B.-826, 02-14-2008 22:06:14
Thanks Man
Jerry
