Super H belt pulley problems
Andrew Kappers
02-14-2008 18:00:59
Hey there. Been trying to take the belt pulley apart on my super h because i believe the oil seal went out and is starting to leak. This is the end that sticks out the right hand side of the tractor which the pulley is bolted to. I got the shaft that goes through the middle out and was able to get the castle nut off the second shaft but not sure how to get the gear off so that I can pull the shaft out. Part # 358234R1. Ben fiddeling around with it but dont want to ruin it. any ideas? Any one taken one apart before? Any help would be appreciated. Thanks
Haas
02-14-2008 18:53:14
 Re: Super H belt pulley problems in reply to Andrew Kappers, 02-14-2008 18:00:59
You will need a bearing separator and a shop press to get the gear and bearings off. Maybe you could take the assembly to a shop with this equipment if you don't have these tools.
