MW 9 Speed
billde
02-14-2008 19:17:10
Just read below about the Heisler 9 speed as to pto speed. Does the M&W have the same effect on the pto and hyd?
Harry klever
02-17-2008 18:28:26
 Re: MW 9 Speed in reply to billde, 02-14-2008 19:17:10
i got a m, with a m&w 9 speed attachment, plus a big hand clutch, tractor doesnt run [yet]!!the belly pump wont last long if it run's twice the reg speed!!
r4etired
02-15-2008 08:27:44
With an additional set of gears in the front of the transmission the direct set keeps everything as designed When shifted to overdrive it increases the speed of the bottom transmission shaft,That speeds up all gears,the pto and the belly pump as they are both driven from the bottom shaft,The engineer that designed the double pin shift was very intelligent.
glennster
02-15-2008 10:48:28
 Re: MW 9 Speed in reply to r4etired, 02-15-2008 08:27:44
hmm, never thought about the belly pump. i"ll haveta check my m that has the m+w. learn somtin new every day!!!
ejr-IA
02-14-2008 19:38:28
I have a H that has the M W over drive and it also speeds up the PTO.
